Oxford_Hippo
Guest
Posts: n/a
Question Headlamps - Full Beam problem on 911sc
Hi,
while driving at night, using the full beam, cancelled it as there was an on coming car, then tried to switch them back on and no joy!! full beam on the car has suddenly vanished.
the indicator arm still clicks forward and back,
but can no longer get the full beam on when the driving lights rae on, and can't 'flash' the full beam using the indicator.
Can't get the fogh lamps front oor rear to work now either?
Any tips on what parts I should check first before I take the switch to bits.
Don't have a driver's manual so not sure which is the relay for the full beam.
Any help much appreciated.
Old 09-05-2002, 06:18 PM
The contacts in the stalk switch are a likely suspect - they tend to bend or melt. Here's a good thread with info on this switch, relays and related problem areas:
Brights problem
Do a search here and you'll find lots more info. It's a common problem.
Argo
88 Targa
Old 09-05-2002, 07:21 PM
