adjusting idle on a 930.06 engine (79 SC)
Hello!
After a lot of work done to my California 930.06 (3.0 SC) engine, I now must ask, what I'm probably missing. Reason is: before all of that intake refurbishment it ran cold 2000rpm to settle to 850rpm within max 30 secs and did about 420km before I filled her up with about 60l (average 14l/100). The engine is freed from: - AC kompressor - airpump - exhaust gas recirculation - pre74 heating backdate The intake was fully dismantled, cleaned, resealed, new fuel valves, valve sockets, new fuel lines, o-rings, throttle gaskets, airfilter, etc. Timing was refurbished/renewed too (dizzy, plugs, cap), beru wires are fresh and contact ends are blank. The car runs strong, and feels much better on the pedal as before. BUT! - it now runs 2200rpm to settle to 1000rpm way over 30 secs and I had to fill her up after 355km with 62l (average 17,5/100) I reduced airflow on the throttle with half a turn, but no difference. Any clue?
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Measure the exhaust gas CO and reset the fuel mixture.
JR |
