RS/RSR High/low Butterfly Throttle Body Assemblies
Why was there two different styles? Did one make more power at higher RPM? What size where the RS/RSR Throttle Bodies?
Old 06-16-2006, 10:50 AM
BReyes's Avatar
RSR more R than RS. But yes mods include bigger, for purpose of greater horsepower output. And can't help but think of the bling factor when you open the lid.
Regards,
Bernard
Old 06-16-2006, 11:14 AM
lateapex911's Avatar
Ah...but thats not "bling"......... those are old school..."bling" to me is showy flashy stuff that serves no real purpose. Like most wings on Honda Accord LXs. Or the "Blue" headlights.....kinda look like HIDs, but less light than a standard halogen, and more annoying to everyone else..
But these...they are the real deal. When originally installed they were part of the ultimate HP package for that particular engine/cam/compression/fuel injection, etc combo.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 06-16-2006, 01:14 PM
Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
Discovered this old thread and i wonder what answer is. Can anyone chime in ?
Why high or low ?
Old 02-20-2014, 01:37 PM
AutoBahned
RWebb's Avatar
my guess would be either torque at lower rpm, or avoiding reversion
a [prolonged]search might be illuminating...
Old 02-20-2014, 01:43 PM
boba's Avatar
The HB were for racing and the low butterfly were for street daily driver. The race motor was optimized to run wide open at high RPM. This include larger ports, valves, exhaust primary tubes, head flow, higher compression. The HB matched the larger ports (high RPM power) and higher velocity flow. The low butterfly was more flexible throughout the power band. Smaller ports pull the power band lower in the RPM range and make it wider. In other words, more drivable. The race engine was peaky with its power band at the top of the RPM range. Not comfortable driving around town in traffic.
The 2.8 RSR was 43mm and the 2.5 ST was 41mm. I think the 2.7 RS was 38mm.
Old 02-20-2014, 01:58 PM
Banned
I've found another thread where the reason for HB was to avoid intake reversion probably due to more agressive / overlapped cams.
Old 02-20-2014, 02:03 PM
Max Sluiter
Flieger's Avatar
They were less prone to sticking than slide valves were.
Old 02-20-2014, 07:07 PM
That is correct.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-21-2014, 12:26 AM
