Tips for 911
Any threads hereto help with a poor running 911 that's been in storage for 5 years? I've drained the gas and the tank and tank screen/ filter look good. The car runs and drives but it does cough or backfire thru the airbox and starts to smoke some once it's warmed up.
Any suggestion for any addititives to maybe clean the injectors? Is the smoke from bad valve seals? Car didn't smoke when I stopped. Driving it 5 years ago. The car does 195k original miles and is a 1980 911 sc targa Thanks for any help or suggestions. |
Hi
I would start with a complete tune-up, including a fuel filter, plug wires, air filter, etc.
Drive it for a while to see if it cleans itself out. If not, do a compression and leak-down test.
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
+1 on complete tune-up as above. I had my '79SC in storage for 16 years with gas in the tank. The biggest problem were the clogged and gummed-up gas tank fuel line connections. I would make sure that you take the tank fuel filter out, and carefully clean the fuel outlet area around the inside bottom of the tank fuel filter area. Get a new fuel tank filter, here at Pelican, it is only about $45.-. Then make sure that the fuel return tube into the tank is clear and un-obstructed. Check with compressed air! Ask me how I know.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
AutoBahned
add some Stabil or similar to the tank, then do the above
You guys are awesome! Thanks for the quick responses and awesome info.
French Import
Doesn't the SC require a pop-off valve to protect the airbox?
I would also take a close look at the fuel lines over the engine for cracks.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
ROW '78 911 Targa
Pop off
I'll check all the other mentioned things along with fuel lines. Head lights don't stay on unless I hold the dimmer switch so that needs to be addressed, man it's always something but I really appreciated the help. Mike |
Wow
Thanks |
Help
Mike |
Pelican Parts - Product Information: 911-613-305-00-M78 That switch with age has the tendency to turn on the bright head lights at the slightest motion. That switch can also be fixed. Here are acouple of links for that: Headlight hi/low beam issue - newbie Hi Beam Switch: Poof! Headlight Switch OK? Lost my low beams. Problem with Steering Column Switch Some headlight wiring help turn signal switch quick fix pictures Good luck!
