Electrical is possessed... Help please
So my left turn signal does not work anymore in the rear, but the front does??? The bulb is fine and I have swapped them out... Also, when headlights are on and I throw a turn signal on they still dont work and when they go back to normal position after the turn, then the high beams go on. Super weird... Is that a faulty Turn Signal/Dimmer switch? Or a relay??? or what???
Old 02-20-2014, 02:04 PM
Under the radar
Trackrash's Avatar
Sounds like bad grounding connections.
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-20-2014, 02:39 PM
Most likely a bad ground connection, especially if it worked OK before the winter!
1982 911SC Wine Red Metallic
OMG I love this car!
Does anyone have a link to a diagram where all the ground connections are??? Thanks for help guys.. I love this forum...
Old 02-20-2014, 02:49 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Grounds.
This is for an '86, but should be close to your '84:
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 02-20-2014, 03:20 PM
fitchn's Avatar
The issue with the high beams turning on as the turn signal stalk returns to center is commonly due to the contacts in the switch itself (on the steering column) needing adjusting (i.e. being worn). There are a few threads on this bouncing around. I recently did this fix on my SC which was displaying identical behavior. Once the switch is removed it is pretty easy to see what is going wrong. A simple bending of the contacts can fix this problem.
The issue with only one of the turn signals working on the same side could be a grounding issue, or a wiring one. You should check to see if the bulb is getting power when the blinker is on. If it is receiving (pulsed) 12V but doesn't light, then you probably have a grounding issue. The connection to ground may test ok using a ohmmeter even if it is faulty.
Good luck.
Noah
79 SC
minerva blue metallic
Eureka CA / Boulder CO
Physics is like sex, yes there are some practical applications, but that's not why we do it.
Old 02-20-2014, 03:50 PM
OG
///Criss's Avatar
My buddy had an issue like that on his SC. It was his contacts in the switch. Shoot him a PM
his screen name is BLYGUY
2002 Suzuki Hayabusa SE... Mega Crotch Rocket!!!
1988 BMW M3.... WWWRRROOOMPP!!!!
1983 911SC (long term Project)
1987 930 GP White Woooosh!!!!!! Burble burble!! Hahaha
Old 02-20-2014, 03:56 PM
Gerry u rock... Keep u all posted!
Old 02-20-2014, 04:04 PM
Fitchn I will take it apart tonight and try to fix
Old 02-20-2014, 04:05 PM
