webco's Avatar
911E crankshaft
I am rebuilding my '71 911E motor and apparently need to replace the crank. (The other option is to cut the one I have and look for -.50mm bearings, re-harden, etc. and spend a fortune.)
My question is: My crank is counterbalanced. Can I replace it with a non-counterbalanced? The part# on the existing counterbalanced one is 901-102-011-00. The used non-counterbalanced I see are listed for sale as 901-102-010-00 but don't see those in the parts catalogs. Any help out there? Thanks...
Old 04-15-2014, 12:12 PM
pors1968's Avatar
Any used 2L and 2.2 except T will do. Try parts for sale they are a couple JONH WALKER you will have good service.
Old 04-15-2014, 01:23 PM
tharbert's Avatar
Posted today: link
By the way, I do believe they are interchangeable.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 04-15-2014, 01:51 PM
I have seen a 2.2T non counter balanced crank replacing a 2.2E counter balanced crank with no running problems. Not a track or racing application.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 04-15-2014, 03:45 PM
Navin Johnson
TimT's Avatar
You can use a T crank in lieu of the S or E crank..
In fact there are some racers who use T cranks in racing applications, since, when coupled with a button clutch, the MOI is reduced and engine revs like mad...
and T cranks used to be much easier to source....
For a street car.... you could never tell which crank you have from the drivers seat..
'69 911 GT-5
'75 914 GT-3
and others
Old 04-15-2014, 06:06 PM
webco's Avatar
Thanks guys. I think I have found a replacement std/std crank that is counterbalanced. Someone told me that with those old mag cases, anything that helps eliminate vibration and stress is a good thing!
Old 04-17-2014, 03:43 PM
