Senior Member
Doug Zielke's Avatar
Engine (Re) Builders......
......what kind of valve spring compressor are you using (that works well with 911 heads)?
Much appreciated if you can post a picture and brand name/part number.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 09-10-2002, 05:37 PM
Navin Johnson
TimT's Avatar
I use the craftmen one, it looks like a giant c-clamp. dont have the part #. Some other manufacturers probably have similar ones, (Snap-On) and are probably priced accordingly.
'69 911 GT-5
'75 914 GT-3
and others
Old 09-10-2002, 06:17 PM
DavidH's Avatar
Doug,
I used a valve compressor tool I bought from advance auto parts. It has relatively thinner arms than some I have seen. It is a smaller version of the one used on my chevy 350. The puller arms are much thinner. Otherwise you have to buy the two (set) that are made for the job. I found with a little patience and brute force I was able to get the job done. It does wear out the palm of your hand until you get used to it. After the first two or three valves you get the hang of it. A small magnet used to get the retainers out is handy and a helper would be a good idea if you have an interested friend. Three hands would have made this a piece of cake.
78 3.2L CIS 911SC
Old 09-10-2002, 06:19 PM
Senior Member
Thanks guys.
Would this kind of compressor work?
Old 09-10-2002, 07:09 PM
DavidH's Avatar
That's the one...It can be done...
78 3.2L CIS 911SC
Old 09-10-2002, 07:11 PM
Senior Member
OK
How about this (c-clamp) type? I think this might be like the Craftsman one Tim mentioned.....
Old 09-10-2002, 07:17 PM
Navin Johnson
TimT's Avatar
Doug thats just like the one I use
'69 911 GT-5
'75 914 GT-3
and others
Old 09-10-2002, 07:41 PM
