Post Rebuild 3.2L with 3.0L crank and 98mm pistons, worth while?
I was wondering is there any potential performance improvement using this short stroke version of a 3.2L? Would it require dual plug heads?
Old 09-08-2001, 08:46 AM
RLJ RLJ is offline
Senior Registered User
Post
The short stroke 3.2 made from over boring a 3.0 to 98mm is a good rebuild idea. The motor does not have the same amount of torque as the long stroke motor but makes revs' faster. Its a trade off. Noi you don't have to go to dual plug if you keep the compresion ration down. I asume you are talking about a street motor with street pump gas.
I like my short stroke 3.2 motor. 281 HP/ 241 ft/lbs. torque at 6100 RPM. at the crank shaft on the dyno.
Randy Jones
1971 911
Old 09-08-2001, 10:04 AM
Irrationally exuberant
ChrisBennet's Avatar
Talking
Randy Jones
1971 911
OMG! 281hp! What is that at the wheels? What sort of induction & exhaust are you using?
Chris
Old 09-08-2001, 03:58 PM
