supercarrera82's Avatar
Door not closing, door latch in wrong position
After receiving my car back from the paint shop one of the lovely workers managed to re position the door latch but accidentally turning it to the lower position and now the door will not close. Below is a picture (not my car) of the part that has been re positioned and now I cannot get it back to the correct position. I know it is spring loaded inside and I even tried taking the spring off and still wont turn the correct way. Ne ideas??
Old 02-24-2014, 12:56 PM
pors1968's Avatar
Are you sure is not lock .
Old 02-24-2014, 02:38 PM
Agfours
agfours's Avatar
Maybe stating the obvious, but did you try pulling the trigger on the external door handle to reset the latch?
Paul
Present and accounted for: 1986 Carrera Coupe, 2021 Audi SQ8...Gone but not forgotten: 1987 Carrera Coupe, 1996 911 Carrera C4S, 1985 911 Carrera Cabriolet M491, 2011 Cayenne Turbo, 2001 Boxster S....Me: "What is your return policy?" FLAPS rep: "We really expect you to keep it..."
Old 02-24-2014, 02:50 PM
Recreational User
porschenut's Avatar
Interior handle pull will set it to the open position again.
Old 02-24-2014, 03:08 PM
Projekt Rostlaube
june82000's Avatar
I'm glad you asked. I thought surely he would have so I didn't bother. Wasn't the door shut when it was picked up from the shop?
Old 02-24-2014, 03:22 PM
redridge's Avatar
^^^ what they said or its stuck and needs oiling.... just turn it counter clock wise so it can latch again.
Old 02-24-2014, 05:20 PM
