Door not closing, door latch in wrong position
After receiving my car back from the paint shop one of the lovely workers managed to re position the door latch but accidentally turning it to the lower position and now the door will not close. Below is a picture (not my car) of the part that has been re positioned and now I cannot get it back to the correct position. I know it is spring loaded inside and I even tried taking the spring off and still wont turn the correct way. Ne ideas??
Are you sure is not lock .
Agfours
Maybe stating the obvious, but did you try pulling the trigger on the external door handle to reset the latch?
Paul Present and accounted for: 1986 Carrera Coupe, 2021 Audi SQ8...Gone but not forgotten: 1987 Carrera Coupe, 1996 911 Carrera C4S, 1985 911 Carrera Cabriolet M491, 2011 Cayenne Turbo, 2001 Boxster S....Me: "What is your return policy?" FLAPS rep: "We really expect you to keep it..." |
Recreational User
Interior handle pull will set it to the open position again.
Projekt Rostlaube
^^^ what they said or its stuck and needs oiling.... just turn it counter clock wise so it can latch again.
