901 Hargett Shifter measurement request
I've got a 901 transmission installed in my Rally Beetle, and I'm working on the install of a Hargett shifter and hydraulic handbrake. I've run into a bit of a snag, and could really use a measurement from someone who has a 901 equipped 911, using the Hargett shifter:
How far right (in inches or millimeters) does the top of the knob move from neutral to 4th/5th? I realize the side-to-side axis has adjustable stops, but currently my car has no engine...thus I can't really "test" where to put my stops. How far the shifter moves will determine where I place the vertical hydraulic hand brake, and I'm stuck until I get a dimension (even a ballpark) to work with. Flipped the shifter mount in my build: ![]() The car: ![]() -Dave |
I would rather be driving
Sorry. I can't help. My hargett is sitting on the shelf waiting the next project.
btw. GREAT CAR! Is there a link to the build or events?
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Thanks!
Built it myself from the ground up. Had help with one heater channel, and had someone else spray the paint, otherwise it's 100% built by me. Build thread is long, at 33 pages...but can be found here: Dave's 1971 1302 Not-So-Secret, Secret Project Build - GermanLook Forums This is a lot shorter, and gives a pretty good idea of what's involved. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() -Dave |
