"farking Porsche hero"
Rich Lambert's Avatar
Broken wire inside fuel tank sending unit
It's the wire that goes into the little terminal clamps on either side of the plunger. I'm assuming this is one wire that's broken in half at the very bottom of the unit. Is this even fixable? If so, how is it routed on the piece at the bottom? Anyone have a picture of one with the wire intact?
I'd really like to fix this myself rather than shelling out $120 for a new one.
Invisible wires...
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 05-15-2010, 10:19 PM
Eddyvdw's Avatar
Here you go.
Mine has a slight problem though, the fuel warning light is on all the time....
Any suggestions?
Ed
Old 05-16-2010, 01:32 AM
peon77's Avatar
Guys
I had the same problem and used this article to fix mine.Pelican Mini-Technical Article: Repairing the Fuel Tank Sending Unit
I had some wire in my garage that I took one strand from for a replacement wire. It ended up taking about 10 min to fix.
75 911s
86 951 sold to make room for baby seat
09 335i 6MT
NVH
Old 05-16-2010, 05:38 AM
Ed & peon77, thanks for the replies and the pictures!
I replaced the wire, cleaned all the terminals, put it back in the tank, and the gauge is reading full, but I know it's not full.
Hmmm...does anyone know what the resistance readings should be for say, a half tank?
Rich
'66 911 #303872
'07 Cayman
'17 Macan
Old 05-16-2010, 10:02 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Rich,
For our '86.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-16-2010, 10:21 AM
Thanks Gerry. At least now I know what it should be.
For some reason the resistance is not changing as I move the float up & down and the gauge reads full. I took the sender completely apart, cleaned all the parts, re-soldered everything, double checked that everything's in the right place, and...no change. It worked perfectly before and the only thing I found wrong was the broken wire. I've tried 3 different wires of various gauges, but the outcome is the same.
I guess the next step is to find a local with a known good sender and go from there, hopefully eliminating the gauge as the issue. This should be such a simple thing and I've spent all day on it.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
Old 05-16-2010, 05:49 PM
Rich,
Please be reminded that this is for our '86.
Your gas tank may be of different specification/capacity.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 05-16-2010, 06:46 PM
Eddyvdw's Avatar
Are you sure the long wire doesn't touch ground?
The risky bit is at the bottom of the sender (see picture).
Ed
Old 05-16-2010, 10:14 PM
Ed
I routed the wire exactly like your picture.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
Old 05-17-2010, 10:12 AM
Rich
i tried the same thing your trying the wire is very delicate i soldered new wire and physically it work fine until it went back into the tank
the olhm rating changes and the guage reads full (checked ground)
i purchase the new sending unit it took 7 minutes to install
the guage is fine and working
sometimes it pays to go new
2 hrs trying to repair it
7 minutes and $120 to install new
its a no brainer to me
new was better
bob
Old 05-17-2010, 02:59 PM
got a used one you can have. out of an '89.
206 637 4071
Old 05-17-2010, 03:04 PM
Thanks John...I'll take it.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
Old 05-17-2010, 04:11 PM
Hello apology. Might you tell me what were the 3 types of wire you stole without success? in my country I can not pagarel cost of a new united. Nor can inmportar.
Old 02-28-2014, 05:16 AM
