Windshield washer problem
My windshiled washer only works on the passenger side. I have checked to see if the nozzle holes are clear and they look fine. Any suggestions?
Paul 1986 911 Coupe |
kb mercedes GLK350 2009 boxster s 86 targa |
Have you checked the hoses running to the jets? I had one that wasn't spraying because the hose was disconnected. The washer fluid was just spraying in the front boot.
The windshield washer system uses check valves that are in-line with the hoses. They're located right under the nozzles. Have you checked to make sure they're working? Mine were plugged and I had to replace them.Take them out and try to blow some air through them.
Good luck
Ron '96 993 C4S happy again ![]() '03 996 gone..... No regrets ![]() '95 993 gone.... So sad ![]() '70 Signal Orange 911T Targa (gone but not forgotten) |
