-   -   Door Light Switch Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/79902-door-light-switch-problem.html)
FranksPlace2 09-07-2002 10:48 AM
The interior light on my Targa didn't light when I opened the door. I fixed the right door switch by removing, cleaning and reinstalling. When I took out the switch on the left side, there was no wire. I fished around but could not find it.
Does the wire come from the top ( where there might be hope it's reachable) or the bottom?
Any ideas on a fix?
Thanks for your help.
Frank
'77 S Targa
Engine rebuilt
RoninLB 09-07-2002 03:17 PM
may be able to find wire from cabin ..under dash on left side.look for rubber grommet on left bulkhead.may have to pull back some glued on shag/fur material...know wire color...remove grommet and sw. wire. then use a stiff wire to use as a feed from under dash hole to find switch hole..now you can tape your sw. wire to stiff wire .........Ron
FranksPlace2 09-14-2002 01:42 PM
I spent the day fishing...
I drilled out a small rivet holding the carpet, pulled it down to get some access to the bulkhead penetration, found the brown light switch wire.
Unfortunately I could not get my fish wire to the other side. I tried from both ends but no luck.
It can't be far because the brown switch wire is short.
Is the door hinge structural shape a closed square panel with only a small hole for the wire to pass through? Or is it a U shape and something else is blocking the wire?
Thanks for your advice.
Frank
RoninLB 09-14-2002 02:08 PM
I got my fish wire thru ..from the inside to sw. hole. using a small flashlite into the sw. hole ........Ron
North Coast Cab 09-14-2002 04:18 PM
Once you get it hooked up don't forget to check the overhead light itself. The contacts on the right can loosen over time and cause intermittent operaton. A quick push on the copper contact solves the problems.
JG
