Student of the obvious
What do you think of this RS clone?
OK... you guys missed my birthday (April). All will be forgiven is this is delivered to my doorstep in the next week or so.
http://adcache.collectorcartraderonline.com/10/9/6/32217796.htm |
Nice, from what the pic's show.
My question is why the owner stopped at a 2.5 ltr........ For what he was trying to accomplish, upping the disp to 2.7 couldn't hurt that much $$$ wise, from a "big picture" standpoint. Power wise he has more of a 7/8th's RSclone, IMHO. I'd hate to be in a pack of RGruppe RS's & RS clones with that car..... Just a gut feeling.
Johnny Riz 1973 911 Custom Euro 3.2L "Sports Purpose" '10 Subaru WRX-STi Hatch - modded. RGruppe#152 Early 911S Reg.#335 |
It's a good looking car from the pics, but they don't show much.
But I have to rant a bit about this strut brace in the car ![]() This is very poorly designed and actually hurts the geometry. The diagonal brace is connected to the main brace, maybe 1/4 in from the strut tower. The diagonal is supposed to make the towers rigid through triangulation. Instead this design causes the main brace to bow under corner loads (either up or down depending left or right turn). Bowing the brace CHANGES the camber by pulling the towers together. The diagonal should have been tied directly to the tower, not on the main brace.
Chuck Moreland - elephantracing.com - vonnen.com |
Looks awfully nice to me. If that 2.5 is a short-stroke using high-compression 90mm pistons with that MFI system, I'll bet it screams in that lightweight chassis! -- Curt
never mind...
Mike Patterson Obsessive in Texas 86 3.2 Black on Black Carrera Coupe 73 BMW 2002 Verona Red |
Why a 2.5
Probably started with a 2.0 or 2.2 and didn't want/couldn't afford to change the crank/rods when he redid the motor. Also I would think that if you limited the size to 2.5 you might be able to get away with using a 2.4S MFI setup and not have to pay for an expensive rebuild of the Injection Pump. A 2.5 is what I was looking at doing for my car when I rebuild it next winter, but I have notice that Andial has 2.9 93 MM P/C sets, if I used one of those with the 2.2 crank I'd get a 2.7 shortstroke motor, hmmmmmm
Robert Currently Porsche less (but the wife has 2) |
2.5
If you already own the 70 Pcar and it happens to be a coveted "S"model, the motor transformation to the 2.5 configuration alone would cost you around $10,000.00. Do the arithmetic, sounds like a very good opportunity for someone to be an Rgruppe member. The 70-71 model early car were the lightest (weight) stock car Porsche produced. I believe they started at 1020kg's, which was lighter than the RS (73)...
I sent the seller e-mail asking about the engine. I'll post here if he replies.
Hold on guys.. don't rag on it because it "only" has a 2.5 motor. The internals could be a nice mix of ingredients that yield more power than a 2.7. Sure, the car has some faults, but if the rest of the package is decent, at that price, it could be a very good buy.
And it would keep up with the R Gruppe. (Do any of you remember that IMSA had a 2.5 liter class where the Porsches dominated?) |
"(Do any of you remember that IMSA had a 2.5 liter class where the Porsches dominated?)"
Yes we do. Even worse case scenario on this motor, it appears to be a 2.4S spec, except more displacement. That would put it at 200HP - not far off of the real RS2.7, but in an even lighter chassis. And don't forget that a "2.4" is actually only a 2.34, a "2.5" is actually a 2.52, and a "2.7" is actually only a 2.68. Not that I'm biased toward 2.5 liter motors. -- Curt
Hey Curt
Checked out your "gray wolf" Cool car!! Love the color combo too. |
Hey, thanks. It's unique for sure. -- Curt
2.5= 260HP
Hey Curt, from the 2.5 specs given to me by someone "notable" it should dyno around 260HP....
Well, I 'll be right up front and say, I stand corrected !!!
I guess the potential HP #s with all the right goodies is quite decieving, if one(me) just looks at just the displacement. So right on, Very nice RS clone Indeed. and thx guys for the education
"Hey Curt, from the 2.5 specs given to me by someone "notable" it should dyno around 260HP"
260??? Holy Schmolies. -- Curt BTW: got the RS stickers today. Check's in the mail!
OK, so what are the specs that result in a 2.5/260? This thing has single plug ignition, so I'm guessing compression is maybe 9.5 or so. He's got S cams and heads. Where's the HP come from? I remember Otto said he could get 260 out of a 2.5 as well. -- Curt
Is it me or does it look like he removed the RPM Transducer on this MFI motor?
Is it likely he has a workaround or is it reasonable/practical to eliminate this fuel cutoff component for racing purposes?
John - '70/73 RS Spec Coupe (Sold) - '04 GT3 (Sold) |
But when twin plugging a 2.0 [ race engine ] the dyno shows a 10hp increase. Give him a buzz, the number's in Excellance. Regards. |
2.5..
I can send you the recipe for the 2.5 motor if you would like Curt. I "thought" I might want to add bit of "boom" to my 70S, until reality set in about cost for engine mods. This 2.5 transformation would be in the $10,000.00 range. I then walked out to the garage, started up the Rgruppe car. Upon returning from a very agrressive freeway lap, I decided the S is what it is and to "just leave it alone".
You'd play hell replicating this car for the asking price...looks like a nice hot rod to me!
