-   -   Unique instrumentation on 2.8 liter build (http://forums.pelicanparts.com/porsche-911-technical-forum/800185-unique-instrumentation-2-8-liter-build.html)
Draden 03-07-2014 09:25 PM
Innovations and custom installations. Contribute yours please
Hi, I've received several PM's about some instrumentation I designed into my car that people saw at the recent lit show and figured I'd just create a post to explain some of the installation and operational aspects of them
Lets start with the aircraft engine analyzer but first let me explain my addiction comes from being an engineering test pilot for a major business jet manufacturer so I can't resist the constant temptation to perform avionics engineering or aerospace engineering on my car.
What your looking at is called a US-8A and it is made by EI instruments
I'll shows some pictures first, talk about the installation and then it's usage
http://forums.pelicanparts.com/uploa...1394253945.jpg
http://forums.pelicanparts.com/uploa...1394254059.jpg
The instrument has 16 k-type thermocouple inputs for various types of sensors
For the left bank of channels 1 - 6 I have cht (cylinder head temp 14mm ) sensors under each lower spark plug on the twin plug heads on the right bank of channels 1 - 6 I have egt ( exhaust gas temp) probes drilled and mounted into each pipe at 1.5 inches from each exhaust valve. Channel 7 left is a p120 k-type sensor mounted into a manifold block connected to my lower transmission drain plug which feeds a check valve posited up at the level of the transmission fill plug and goes to a oil pump, cooler then expands from -6an to -8n to reduce pressure before returning to a 90 degree swivel an fitting drilled and tap threaded into the 901 directly above the ring gear. The check valve and diameter change are critical to keep the oil level at height so when pump is off, the oil cooler doe not over fill the transaxle and the diameter change is so I don't pressurize the case and blow seals when in operation.
Back to the gauge, the right channel 7 is again a p120 temp sensor but this one is mounted to the top extra cap port on my front right wide mouth oil cooler
So you can see that channels 1 thru 6 give me cht and egt for each cylinder and channel 7 is trans oil temp on left window and external oil cooler temp at the right front fender. Channel 8 unused (for now)
Now the gauge can be programmed for upper, lower and differential limits. One can use the center switch to manually step to each channel or place it in scan mode where it constantly scans the user defined limits and flags the red lights if something goes outside limits.
For tuning the PMOs, it comes in handy big time. I can adjust my fuel air mixtures and idle air correctors until all egts are all within about 25 f of each other. Typical idle at 900 to 1000 rpm is around 1100 f. If a cylinder is rich , it lowers, if lean raises and if clogged jet or not spark then of course it's way down near 100 with the others still at 1100. ( please note I have dual mtx-l air fuel sensors gauges and use my carb sync to open and balance the air correctors to match vacuum on each cylinder and open them all equally until I obtain a perfect 12.5 to 1 on each side bank of three. This with the egt helps me idle a 906 cam (early rsr) cam 318 and 292 duration with the 906 1.5 rockers instead of standard 911 1.45 and idle like any new production car. Smooth.
Also the air correctors opened a little give me a better progressive with zero flat spots when transitioning to mains.
I don't have 2.8 liter secrets so the pistons are JE 92mm with 25.5 volume dome and the heads are 74 modified to 42 intake and 38 exhaust ports with standard 46/40 valves and 68 cc chambers giving a CR of 12.0011 hence why I run vp 101 street legal unleaded for good measure (specific gravity of .713 @ 60f)
Head valves and ports match the pmo carbs and Venturi. 46/42. And for exhaust the head ports 38 matches the 1.5 inch headers (38mm)
Back to the gauge
It provides me with a very safe and early warning monitor of engine parameters which can be costly and ring damage etc if not caught instantly.
It helps me tune to a level beyond what a plug read can do
It's just good insurance and it's cool and fun to use and tune with.
The next picture is of the afr gauges
http://forums.pelicanparts.com/uploa...1394255963.jpg
They obviously help me tune for power.
In the earlier picture you can see the bung welded aft of the merge for the left bank exhaust for cylinders 1 2 and 3. Note there is an aluminum heat sink that is finned between the bosch sensor and the bung that must be oriented with the airflow direction and reduces temp at the o2 sensor to prolong life. Same for the right header cylinders 4 5 and 6.
These help me set idle up thru 8k and can be logged via computer link when driving under load to see afr vs rpm
I target 12.5 to 1 because most know that is best power whereas 14.7 to 1 is best emissions.
I run the PMO 46 with 42 Venturi and 160 mains, F 2 emulsions and 180 air correctors to obtain within plus or minus 1 of 12.5 to 1 all the way up.
Any questions. Feel free and I don't want to re read this so I hope no typos.....
Draden 03-07-2014 10:06 PM
http://forums.pelicanparts.com/uploa...1394258714.jpg
http://forums.pelicanparts.com/uploa...1394258753.jpg
Flieger 03-07-2014 10:43 PM
Only a real pilot would state the specific gravity of the fuel he is using in his car. :)
Draden 03-07-2014 10:52 PM
Awwww Max. I thought we get to be astronauts today... Ha ha. Wanna see my watch?
And my favorite story (told with hands demonstrating the aerial maneuvers)
There I was..... inverted as I closed on the space shuttle while it was re entering over Texas....
Couldn't see **** because my air medals we dangling across my visor.....
Flashing my high beams at the SR-71 that wouldn't give way to faster moving traffic......
ClickClickBoom 03-08-2014 11:23 PM
Trump:
If you know who Scott Crossfield is..
http://forums.pelicanparts.com/uploa...1394349763.jpg
He signed my logbook!
Doc Sake 03-09-2014 05:25 AM
All you flyboys will have a damn hard time making the corner with your wheels in the air.
I am Draden's twin brother. I heard a rumor you got the car out for it's debut- so I came in to give a peek at all the commotion. Nice Job, car looks great and I heard is running spectacular.
Trump: Draden's brother is a NASCAR Craftman Supertruck crew chief. And a pretty damn good test pilot in cars (performance driving instructor for an exotic car company...ie: Ferrari's and Lambo's)
Draden 03-09-2014 07:46 AM
[QUOTE=ClickClickBoom;7951856]Trump:
Yeah, he's the first man to do Mach 2 and only my all time biggest influence and hero
Ok, that's a valid trump. I'm jealous.
And to my twin brother, yeah it's nice to finally have her back home after 19 yrs and get ca plates back on her.
Felt good to get her to a hometown debut. But she must have thought she was still going to the Hershey pa show. I think we cursed it and brought the rain
ClickClickBoom 03-09-2014 10:11 AM
[QUOTE=Draden;7952091]
Originally Posted by ClickClickBoom (Post 7951856)
Trump:
Felt good to get her to a hometown debut. But she must have thought she was going to the Hershey pa show still and brought the rain. I think we cursed it
I had the pleasure of drinking ice tea with Mr Crossfield while he was waiting for his engine O/H to be completed by Victor.
I was up to my elbows in a helicopter, checking something or another when I looked down and saw this old guy standing and quietly watching me work. I asked him if I could help him and he said "no thanks, I just want to watch, if that's OK" I got to a stopping point and came down to take a break and introduced myself, and he introduced himself as Scott, I said hi Scott, "you have a last name?"(Ex-cop, who likes to know exactly who he is dealing with), he said Crossfield. It took a few minutes to register, but being an airplane geek, the details lined up after a few minutes. We chatted about everything aircraft/flying related, and absolute fountain of knowledge about test flight, but he was very explicit about his "modest" GA experience level. He came back several times over the week and was as delightful to chat with as anyone I had ever met, unlike Gen. Yeager.
When I asked him to autograph my logbook, he signed without hesitation, but when I asked him to sign the cross country endorsement he became a little reluctant. I said "Scott nearest I can tell, for me to get the Smithsonian to take the X-15 off the wires and line up a modified B-52, pressure suit and then wedge my fat butt into the whole enchilada is about the same as me levitating" He laughed and with no small amount of glee, fully embraced the humorous endorsement.
I am looking for a SR-71 pilot for a similar endorsement for chuckles, a U-2 would be icing on the log book.!
Sorry about the thread creep, when I tell this story most people's eyes glaze over and I can tell they would rather be in the dentists chair.
ClickClickBoom 03-09-2014 10:18 AM
http://www.amazon.com/MARATHON-Chronograph-Pilots-Automatic-WW194014/dp/B007A5F288
https://www.google.com/search?q=Marathon+pilot+chrono&client=firefox-a&hs=fg3&rls=org.mozilla:en-US:official&channel=sb&tbm=isch&imgil=jDeGybal3xxi RM%253A%253Bhttps%253A%252F%252Fencrypted-tbn2.gstatic.com%252Fimages%253Fq%253Dtbn%253AANd9 GcRczbJmtKUrwERBq6szAajoUJADci22EPVH5SMvaiti7c4Jlc-T%253B640%253B480%253BOty29J4nw_bQ-M%253Bhttp%25253A%25252F%25252Fforums.watchuseek.c om%25252Ff29%25252Ffs-marathon-chronograph-pilot-watch-429453-2.html&source=iu&usg=__j0ONZGsQWO155Qq-uRRDx3TwUyE%3D&sa=X&ei=GKIcU8zICOPW2gXcnoDQAg&ved= 0CF0Q9QEwAQ&biw=1920&bih=1066#facrc=_&imgrc=jDeGyb al3xxiRM%253A%3BOty29J4nw_bQ-M%3Bhttp%253A%252F%252Fforums.watchuseek.com%252Fa ttachments%252Ff29%252F315488d1282521374-fs-marathon-chronograph-pilot-watch-20100822_img_0458.jpg%3Bhttp%253A%252F%252Fforums. watchuseek.com%252Ff29%252Ffs-marathon-chronograph-pilot-watch-429453-2.html%3B640%3B480
ClickClickBoom 03-09-2014 11:51 AM
More thread creep:
Interesting read:
Bill Weaver SR-71 Blackbird Breakup
Dr J 03-09-2014 12:29 PM
Back on topic, not to say that the off-topic was bad at all!
I have done this in my head many times. What egt sensors did you use? When you multiply by 6 it starts getting expensive.
Flieger 03-09-2014 12:47 PM
He used K-type thermocouples (cheap) but not sure if his dash piece can read the thermocouples or if he has an intermediate reader.
Draden 03-09-2014 04:53 PM
Yes max is correct k types are cheap. however sorry, I am using the isolated type that are not ground common and thus very expensive.
P-110 fast response k type probes, about 100 each before tax and shipping. Check like aircraft spruce website. The gauge takes the thermocouples right to the instrument connector ( no converter) so you have to buy the wiring and route it as well as the little yellow disconnects that are Also bi metal cr/al These guys areexpensive and the Whole install is about 3500 without labour with clamps connectors, wiring probes circuit breakers under the dash, Backlighting relays so off is full bright led w/bezel and lights on is switched to the car dimmer for bezel and disable led. I can provide wiring diagrams to anyone serious. I'll have to re draft them cause they are hand drawn and added to my manuals.
Please note that these k type are the expensive ones that are ground isolated meaning they cannot touch airframe ( sorry, car frame) ground. They are the chromel and alumel type with the wires soldered at the tip and encased in ceramic inside and isolated from the outer metal probe cover. There are k type that can be grounded but not these plus those kind suck cause they are prone to airframe noise and give error.
Don't use the grounded type
Especially around the spark plugs. Or you will have ignition or everything else using your signal wire as a return path.
For those who need a quick understanding, k type thermocouple measures the difference at the junction of the two metals being joined and is immune to wire resistance. In theory, you could run a chromel and alumel pair from NY to CA and accurately measure the temp without the wire length affecting it
The weak point is the cht probes, you have to use 14mm type and bend the tab up 90 and place it on the plug with deep socket and extension and go all the way up into the lower plug path and lock these down and get your wrench back out without crushing the metal tab and ceramic inside while torquing the lower plugs. If your not careful you can break fins, or crush the sensor. It's tricky and if you try it you'll see why I used the lower plugs. Easier to access and see down with the motor installed.
For single plug, I would not try this unless motor out.
I also use lower because the cooling fan is more directed on the upper and lower is worse case scenario for temp. ( assumed but not actually compared)
Egt probes are easy. Reliable. Accurate and very useful.
After running the. Cht I trust my engine and could live without the cht guage as I never even come close to head temp issues. ( probably because of the high octane, dual plug and running slightly rich all keep my temps down well below any concern.
It all works for my engine
I absolutely could not live without my egt monitoring now. I'm so spoiled having it and would hate to tune or run without it now. I use it. A lot
Again, any questions for anyone interested. I will gladly help.
They have a lot of gauges out there.
I happened to do side work for a friend and did the upgrade on his aircraft to a more advance glass cockpit display that had engine monitoring and more. So he gave me the gauge and bought me new probes etc as payment for doing the removal and upgrade installation on his aircraft.
Of course I knew I wanted that thing in my car. It's fast enough response. Honestly I think the non fast response probes would be just fine but there is a small delta in price so I just went for the others cause it was part of the deal I struck with him as payment for work I did for him.
Putting the sensor on the pipe is easy, drill th hole where you want it and put the probe in with the bad clamp. Make sure the metal sealing washer is there so no exhaust leak.
I never calibrated mine. I just made sure they were all 1.5 away from the flange at the head end. The probes are made with c clips on the inside and outside that can be slide to change the depth of the probe, the more in the pipe the hotter the reading, the shallower the lower the reading. You can adjust and cal these with the headers off and flowing a set temp thru with a heat gun and external calibrated fluke meter probe or some similar setup but really, getting each cylinder even within a 100 of each other is way good enough and you'll see adjusting that a little change in the idle screws changes a lot. You will achieve a much better balance by adjusting and watching these than just the old fashion "turn in until you hear rpm drop, then back out to rpm normal and add a little turn for good measure" type of approach.
Try that without looking at the gauge, then go back and try it again with the gauge,
Plus mounting the gauge by the driver door gives me view from the engine compartment ( for the most part). The right carb of course is farther but I have long arms being over 6-4. I just manually step advance the gauge led to the cylinder I'm adjusting and turn the idle screw til good.
Of course like I said in the earlier post, you have to balance the air correctors for equal vacuum and all that after you first set idle stop and linkage etc etc etc. you know the Richard parr long version.( PMO carb designer for those who don't know Mr Parr). Everyone should know him
NY65912 03-09-2014 05:03 PM
Very impressive. Roninlb would have loved this thread. Rest well Ron.
Draden 03-09-2014 05:29 PM
There are a lot of newer LCD type gauges on the market. Again look at aircraft spruce or a similar website for engine analyzers if you have an old fashion non ecu controlled engine with no closed circuit feedback. Ie fuel injected relying on o2. This enhances carburetor type engines and the adjustment of.
Please please note. Do not use the ground common type. Your engine case has too much electrical noise on it.
It is the ground for your alternator and your ignition spark plugs. Remember that the ignition system and anything else grounded to the case must return to the battery to complete it circuit. This means mated to the tranny then the ground strap from tranny to car. If you use grounded type, then the spark plug path can jump onto your signal wires and return to ground through your gauge making the reading very erratic.
Many people eat clutch cables because they don't realize their ground strap is bad and the voltage travels down the clutch cable as a return path, making it brittle from electron flow and thus prone to breaking.
You'd be surprised how many Porsche and VW and other type of car owners don't know that especially since most engine mounts are rubber isolators.
Breaking clutch cables = check ground strap.
jbryan 03-09-2014 10:38 PM
If you know who Bob White is...we shared many a moment around Heidelberg on the autobhans in my Ruf Porsche in the late 80's and early 90's. Small world.
Draden 03-10-2014 04:40 PM
Bob White and Scott Crossfield, yes small world and very very cool stories.
Hey ClickClick Boom. Come on, I bet together we are resourceful enough to somehow get that X15 out of the Smithsonian.
no B52? Well we can ground launch it from the roof of whoever on this forum claims to have the fastest 911.
Ps, When i was stationed to Edwards, I got a chance to take my Porsche on the dry lake bed at speed. Not many get to do that!!!!!!!!!
We got a plan!
Now back on topic, Maybe an airspeed probe with a 40 knot airspeed switch integrated to my homemade spoiler control panel to deploy the 964 spoiler decklid i option on/off the vehicle. Just for a cool nostalgic way that it would have been done back in the late 60s had the Porsche engineering department done it.
snbush67 03-10-2014 04:58 PM
Similiar install fron Ron (RIP).
Originally Posted by RoninLB (Post 5891837)
a 911 guy would have to be nuts to spend maybe $1.5k in parts and 30-40 hours to do a trick install on one of these
http://forums.pelicanparts.com/uploa...1299713338.jpg
I would really like to use this for EGT and CHT, could the CHT come from the air injection ports?
Draden 03-10-2014 07:24 PM
Cool, yes both EI and JPI make gauges. I have flown an aircraft with that model and liked it. I'm not sure the depth of that one. Mine is pretty deep and I barely had room behind the dash where I placed it. The JPI in that picture is nice and had I started from scratch I'd probably went with that model had I not obtained this one in a barter exchange. Nice to visually see all cylinders at once for quick scan. They both have a scan mode. Mine has very bright warning lights that I like so I don't have to watch it. It'll let me know cause you can't miss the light when looking forward out the window.
That gauge has sub d type connectors that mount against the back and can be a clearance issue unless you do it in a center pedestal like shown. It uses the each same k type sensor and wiring.
One negative is it doesn't have the extra channels 7 and 8 and I use both inputs on channel 7 for trans temp and oil cooler temp with 2 open on channel out for future growth.
I'm sure I would have liked Ron, glad to see someone else did this and was innovative.
I think I'd go for the 6 cylinder color egt only display from aerospace logic or maybe the 8 channel so I could keep my trans oil temp and external oil temp. I'd forgo the cht and could do it for about 1200 or less. Cheap compared to the cost of my engine and protecting it from damage.
For mounting cht in the injector holes, I thought about that when I did mine 10 yrs ago. The air fuel charge cools the intake so your not going to get cht. Had I not already had my heads on and engine built I would have considered using the probe type that can screw in and maybe modified a section of the head to accept a mount point. Next time I do head work I'm going to consider a location but I'm twin spark so real estate may keep me on the lower plugs.
You have to consider the fan doesn't blow equal flow over each head via the shroud so mounting these on the top side can be very biased by air cooling effect
Again cht isn't a big deal to me now that I've ran it so long and in ten years never had a cht issue ever. The egt is another story, can't live without it with carbs. Plugged jet, rich or lean cylinder, you know instantly at any rpm
Also note, the UBG-16 shown there I has a lot of input options like fuel flow oat etc that are configured at purchase and makes that unit a bit more expensive than mine. I don't see using the additions. But like I said, I like the display better to see all at once for a quick visual scan.
They have very cool colored and monochrome units now. If I get a chance I might put up a list of what I'd do now if on a budget and would focus on just egt. I'd have to review the install manuals and look and see if I think there would be installation issues not noted like I know would happen with the ground type probes.
pors1968 03-10-2014 07:46 PM
Very impressive . Do you have any 67 wiring harness left in the car
Draden 03-10-2014 08:38 PM
Originally Posted by TCracingCA (Post 7955213)
I think I saw an X-15 supersonic test jet with Porsche gauges!:D
You weren't suppose to be able to see into the cockpit of the x15 in dc. Yeah those gauges, not from my car. Nobody saw me do it. Can't prove a thing.....
Draden 03-10-2014 08:46 PM
Yes, I still retained some of the factory rats nest and added a few items like aircraft cbs and terminal strips and relays to the clutter http://forums.pelicanparts.com/uploa...1394509524.jpg
Maybe one day I'll rip it all and make it clean, factory did a terrible job of routing. Tangled like spaghetti on every car
Draden 03-10-2014 09:03 PM
Elsewhere else, I have nice routing, for example the front oil cooler wiring and you can see the thermocouple wire with disconnect that goes thru a grommet to the p-120 temp sensor in the wide mouth cooler. Please don't ask me to disassemble to get a picture of the top of the cooler, ha ha.
http://forums.pelicanparts.com/uploa...1394509809.jpg
Also the bat cutoff complete with generator field excitation field wire cutoff so disconnecting the battery kills the alternator if engine running
this is so it doesn't stay running and damage it.
http://forums.pelicanparts.com/uploa...1394509914.jpg
The next pic is of my home made spoiler control panel I fabricated out of aluminum and wired up and mounted on the aft side of my hargett shifter
It has deployed and stowed limit lamps, a circuit breaker (pulled) when the decklid is not installed. And a toggle switch to operate the spoiler.
http://forums.pelicanparts.com/uploa...1394510387.jpg
I have a disconnect in the engine bay for when I swap in or out the 964 decklid. 2 wires for the motor operation ( reversed polarity by the switch for stow, normal for deploy). 2 more wires from each limit switch that return to the relays that are mounted on the bottom of the control panel. Each deploy or stow limit relay removes the direction command when the limit is reached and then the same respective relay also lights the respective lamp.
Note that you can just see the black round knob to my hand throttle and actually I can easily reach my fingers down the right side and under the shift rod linkage and adjust it with no problem
snbush67 03-10-2014 09:27 PM
Originally Posted by RoninLB (Post 5891788)
I have looked on ebay and found several types, I really like the way your gauges look.
It seems that most of the cost comes from the probes and leads. So what do you think is the cheapest off-the shelf way to monitor 6 EGT probes at the same time?
I believe that the logger gauge Ron used was 6 inches deep. It would be nice to have single gauge that just does 6 EGT and 2 AFR.
I really like everything that you have done, thanks for sharing!SmileWavy
Draden 03-10-2014 09:35 PM
And I know I will receive many more PM's about my home made 935 type cross brace who's front mounts are stronger than anything out there and is adjustable for camber caster changes. The mounts are actually motor mounts I found on the net and tried them
See pictures in thread above for behind battery and other side near oil cooler wiring.
They are motor mounts for I think mounting a Toyota engine in a nissan whatever, they fit perfect and ii mean perfect.
Let me explain. The mounts are lower down and the bolts go right thru the wall and through the heavy duty factory bumper box frame so they are seriously rigid.
Your front "A" frame ( torsion bar mount) is right down there close so bracing from the shock tower down to these points is rigid and really braces the pan at the pressure point where the "A" frame mounts instead of the commercial bars that mount against the fender line with fender attach bolts.
Also note, my front pan is not stock, I have a wide H shape box frame welded into it at precisely the exact same x y and z axis points for the a frames to mount to pan. I can jack it and photo graph if requested.
The slots are cool because I didn't want the cross bars welded together because I use them to help dial the camber and caster with the hiem end adjusters. Caster adjustments change the cross angle of the bars, ever so slightly, but enough that a welded cross would not allow this. So the slots allow one bar over the other. I used right hand and left hand thread when I built the bars so I can dial the length while attached then lock them down. They cross at almost exactly 90 to each other and I can unbolt one, swing it up and put the full size spare in and bolt it back down, with no clearance issues.
Whichever camber plate I want to adjust, I remove the bolt for the top bar and diagonal bar for that plate, then loosen the 3 plate screws, temp install the bar bolts and dial the bars to achieve the caster and camber I want, then lock the aft outboard screw which is accessible with the bars hooked, then one bar one for each of the two remaining screws under each bar. When the plate is re locked, the bars should still line up and put all hardware back and move to the other side.
Works for me and man is it solid, no flex because the diagonals are actually diagonal down to the front.
Use solid rod ends, not swivel, that'll defeat the purpose of any brace. And I use little steel wedge washers on each side that can rotate to get any angle I need for the rod end to mount connection and then lock it down solid.
Since the cars are mostly 60 rear / 40 front, the mounts add polar weight to the nose which helps and it's only like maybe 2.5 lbs each mount anyway.
I'm sure that will start a debate, but hey with full gas, no spare and all the accessories hung on the car including creature comforts of carpet and matts and door panels, headliner etc. I weigh in at 2250 so my 310 hp still gives me better power to weight than a real R so I'm keeping my comforts. If someone wants to beat me with their R clone, that's all fiberglass look and lightened and a worthy engine, then I can just start removing some weight. But right now I out accelerate, out brake and out handle a real R and that's what the R was about. Being able to compete in a racing power to weight class. If you can do it without fiberglass. Why not. Don't miss the point, the R was for Racing.
If anyone wants to see the cross bar or make one, I can share pics( my profile shows older pictures and new) to each their own. I love the diversity and the debate and individual innovations. No single one is the end all be all, mine is just another version.
Thanks for looking
Draden 03-10-2014 09:40 PM
http://forums.pelicanparts.com/uploa...1394512708.jpg
I located a source for the mounts, I actually bought mine straight from excessive, but for some reason I can't find the exact ones on their website anymore. But this picture here is the exact ones that are slotted and holes in the correct spot etc... I bought mine several yrs back.
Please note the early cars do not have the batter boxes so I never compared it to a later year. On my 1967 there are factory ground stubs on each side and one of the holes in each mount is centered over the ground stude, the other 3 drilled thru the wall and the bumper box frame.
You could t ask for a better fit and a better angle plus locating them using those ground stud as reference thru one of the 4 holes was perfect
Draden 03-10-2014 09:59 PM
I like the looks of this and the price with 1.5 diameter clamp probes included.
I would have to check the manual for guage depth and make sure these are real cr / al k type probes and no ground reference type probes. But this does catch my eye so far for egt only and just 6 channel. You'd have to get good quality k type wire and buy the k type connectors for disconnects at the engine like I did and get a protective sheath for where you clamp the harness along the wheel well edge near each rear tire.
Id really probably go for this is I didn't have mine with cht and with the two extra sensors for oil at tranny and engine cooler
Again, I'd have to find the manual and check the details on size, recommended wiring, etc but so far it looks great. I'd definitely try to find some review online and see if anyone has one fitted in an aircraft and their opinion of the installation and the operation of it.
Mine is more vintage looking and really a high quality unit.
If this has good filtering and resolution than I'd be sold
There is probably an install manual published somewhere online.
http://forums.pelicanparts.com/uploa...1394513942.jpg
snbush67 03-10-2014 10:18 PM
Great thanks, that's more within my range.
I was looking at this ELECTRONICS INTERNATIONAL UBG-16 ULTIMATE BAR GRAPH ENGINE ANALYZER from Aircraft Spruce
Draden 03-10-2014 10:34 PM
Yes what Ron had there is top dog, mine is a very close second. Only because of the all at once display. The filtering and stability of the measurements and the response is equal and so is the reliability and quality of his and mine. There are pros and cons to each
But again, I like the ubg-16. A lot! have used them and it will work. Any others, I'd have to research and see reviews
I just don't want to promote the cht cause my sensors are a pain in the a$$ to install and not screw up. Once good, no problem but one time I damaged 3 just trying to install until I got one in without crushing it with the socket
I know Porsche even engineered a single cht onto just one head on some of their engines, why, probably cause they couldn't find the real estate either. I looked it all up years ago and researched it all and forgot now, but it's probably relevant info to add to this thread if someone wants to recall and add it.
Maybe between that info and this, someone will teach us all a better way in the future, I encourage innovation and hope to gain from others sharing as I do and everyone building a little bit better each time
TCracingCA 03-10-2014 11:02 PM
I guess only a few select people are hit by lightning, and live to tell about it!
http://i58.tinypic.com/5a5v6.png or http://i58.tinypic.com/xbwl08.png
I was trying to follow along, but I definitely am falling behind! Maybe the lightning bolt will hit me!
Draden 03-10-2014 11:24 PM
Does it count when piloting a business jet, I've been hit 3 separate times in a Challenger 604. Looked like the diameter of a tree trunk connecting with the radome one time, scary!
But last time I checked I didn't have any bolts growing out of my neck...... Yet........
Hmmmmmm....... A Porsche with a flux capacitor? .......... Hmmmmmm
Draden 03-11-2014 12:04 AM
Man, what I would do if I could have a pair of those front wheel motors and kers system off a 918 ( and maybe a kite string and a key in an electrical storm)
I don't even want to imagine the replacement purchase price for them.
Maybe in ten yrs I'll have a front wheel electric drive system augmenting the power on my 1967
I have though about it already and looked to see if anyone is making any kind of components The engineering involved is major. Placement and activation of the drive vs energy recovery. And storage systems that are weight effective. Lithium etc etc And the inertia speed. Omg 20 k rpm and greater on drive train recovery wheels. To be effective. Wow
Way out of my budget or anyone's right now, but some day......... I hope to do it
Draden 03-11-2014 12:07 AM
I just looked at that post above from tcracingca and forgot what I was even thinking now
Nice, I'm sure the view count of this thread will multiply. Wow
Ok in an attempt to get this back on topic about innovations and unique instrumentation and concepts
......... Next post
Draden 03-11-2014 12:23 AM
More pictures of the spoiler control panel
http://forums.pelicanparts.com/uploa...1394522555.jpg
http://forums.pelicanparts.com/uploa...1394522596.jpg
Draden 03-14-2014 11:12 PM
Pictures of the cht/egt wire routing
Pics of the k type wire routing
http://forums.pelicanparts.com/uploa...1394863764.jpg
http://forums.pelicanparts.com/uploa...1394863820.jpg
http://forums.pelicanparts.com/uploa...1394863846.jpg
http://forums.pelicanparts.com/uploa...1394863885.jpg
http://forums.pelicanparts.com/uploa...1394863928.jpg
Draden 03-14-2014 11:16 PM
More
More moving aft
http://forums.pelicanparts.com/uploa...1394864021.jpg
http://forums.pelicanparts.com/uploa...1394864061.jpg
http://forums.pelicanparts.com/uploa...1394864094.jpg
http://forums.pelicanparts.com/uploa...1394864125.jpg
http://forums.pelicanparts.com/uploa...1394864162.jpg
TCracingCA 04-11-2014 12:10 AM
I saw your car at the California Speed Festival!
Good turn out of the Socal hot rod "Race Inspired" older 911's!
http://i60.tinypic.com/243oi1w.jpg
http://i59.tinypic.com/2lc5wr7.jpg
And a bunch of other nice ones!
http://i58.tinypic.com/3322v4i.jpg
And the R Gruppe turned out in mass!
http://i60.tinypic.com/28lfcsg.jpg
And the new GT-2 RS
http://i57.tinypic.com/femgs9.jpg
And I heard this guy had to buy a car to get this license plate away from another owner!
http://i61.tinypic.com/33wqxk9.jpg
http://i59.tinypic.com/2cfpdlx.jpg
http://i60.tinypic.com/2egd4px.jpg
http://i60.tinypic.com/sd2qzk.jpg
http://i61.tinypic.com/20sf69g.jpg
Pstallo 03-14-2015 08:15 PM
I was looking at CHT gauges, but I wasn't sure what thermocouple to use if I wanted to hook one up. Is it a 14mm? They also have 7ft or 14 ft extension leads. Is the 14 ft extension what most people run to reach from the engine to the front of the car?
gordner 03-18-2015 02:43 PM
I used an MGL avionics TC-3 (MGL Avionics - Velocity) when I installed my EGT/CHT system. It is a fabulous tool, I installed it after I switched from CIS to Webbers as i was worried a blocked jet could lean one cylinder out and burn it up without my feeling it. It is an incredible tool for tuning the webbers as it gives me an output for each cylinder. The CHT also told me when I had failed to orient some of the engine tin correctly and was not getting airflow over the #3 cylinder head.
The TC3 is very cost effective at $375, bu the good probes will run you about 100 per. I got mine used from an aircraft removal through Ebay, got ten for 200 dollars.
gordner 03-18-2015 02:46 PM
You can make a CHT probe by twisting an alumel and an inconel wire together and soddering it to a 14MM washer. In my install I actually drilled the corner of the hex of the spark plug and wired directly to it with an inconel and an alumel wire, works perfectly and is easy to install.
