Kind of noise when I accelerating???
Hi friends,
I have a weird noises From the back of the car ( knocking noise) on my 1983 911sc when I'm accelerating only after I pass 4000 rpm,
Anybody have any idea what this is???
I thought maybe it from one of the Axle Shaft
thanks
tom
Old 03-07-2014, 11:50 PM
RaketeRot
Draden's Avatar
Passing 4000 rpm while in what gears. 1, 2 , 3? All? Neutral? If your basing this on an accelerating engine speed (especially only under a load) and not a drive train speed then what's your octane level? Bump it up or retard your ignition.
Your advance is full in at that point. Does the knocking taper off if you decrease load but maintain speed?
Do you have the stock vacuum advance type distributor installed?
If so vacuum should retard under load and if broken well. Timing is off. Does it look like this?
1967 911R hybrid clone
1973 911 RSR - coilovers, 2.8L twin plug RSR cam engine. butt welded metal RSR flares and metal frame ducktail
If it were easy, it would not require people of our caliber.
Old 03-08-2014, 12:48 AM
RaketeRot
Draden's Avatar
Old 03-08-2014, 02:09 AM
pors1968's Avatar
I had a similar noise over 3500rpm and it was head stud but it could be your axle and agree whith DRADEN these distributor the advance are prone to seize or vacuum
Old 03-08-2014, 03:39 AM
Thank you friends
Draden the Vacuum tubes of distributor are new, I have two pipes that connect to it, i try to get photo of the distributor ,
retard my ignition is done by Rotate the distributor on its axis and tune the ignition?
I'll drive the car later today and check like you recommended exactly when I have the noise and I'll update you ,
pors1968 about the head stud that you say , its Should only strengthen them?
I mean, to close them???
thanks
tom
Old 03-08-2014, 03:59 AM
pors1968's Avatar
The two thing you can do is compression test and take off your exaust valve cover and check if twelve studs are there.First do you have any oïl leak near cylinder barrel.
Old 03-08-2014, 04:06 AM
My engine without leaks, totaly dried,
I'll check again now that the noise started yesterday,
maybe i have anew leak,
i hope you are wrong
Old 03-08-2014, 04:20 AM
pors1968's Avatar
No leaks it good news i am probably wrong.
Old 03-08-2014, 04:24 AM
ok
i look and my engine dry with no leaks
this is my distributor
Old 03-08-2014, 04:44 AM
Old 03-08-2014, 04:46 AM
Old 03-08-2014, 04:47 AM
Old 03-08-2014, 04:48 AM
Mo money = mo parts
I doubt that it has anything to do with an oil leak. Pors1968 was suggesting you look at the base of the cylinder near the case to see if you had any oily residue on the case. It is not going to be dripping, just black residue on the case. This would be my top vote too, but you really need to look above the heat exchangers to see.
The compression test would confirm, or just pull the valve covers off to look for a broken stud.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 03-08-2014, 04:54 AM
I will check that , thanks,
I remember now that the noise I had yesterday was when I drive on 2 or 3 gear and was very similar to the noise that apear when you start driving on second gear ,
I will do drive test later and update ...
I thinking maybe one of my piston don't get spark ????
Or something like that ...
I hope I don't have broken stud ,
If I opend the valve cover , do I need to buy new seal ?
I never deal with porsche engines before.
Tom
Old 03-08-2014, 05:10 AM
Hi Friends, Yesterday I played some ignition wires before I did a test drive and everything is fine, the noise disappeared...
I was almost out of gas, the lamp came on and I went to the gas station (I use 95 octane).
I have no idea if this is what solved my problem of noise, but anyway thanks everyone for the help...
I hope noises will not return
Old 03-08-2014, 10:54 PM
