Look what just got posted in the classified section for cars!
Based on this design, I'd suggest more zip ties! Is this ducting off a shop vac? http://forums.pelicanparts.com/uploa...1394492005.jpg |
Hey Jack, here are a couple solutions I found looking around.
This isn't the prettiest, but the parts could be found here pretty cheaply, and would lose the weight. http://forums.pelicanparts.com/uploa...1255905569.jpg Source: http://forums.pelicanparts.com/4959829-post2.html This is by far my favorite, but would involve some creative methods to access the rear tins of the engine if the engine isn't pulled. http://forums.pelicanparts.com/uploa...1278306553.jpg http://forums.pelicanparts.com/uploa...1278306585.jpg http://forums.pelicanparts.com/uploa...1278306611.jpg Source: http://forums.pelicanparts.com/5438372-post8.html |
Yes - that last one is the hidden heat set up very stealthy, clean and light. Also not terribly expensive or difficult if you could attach the heat nozzles to the engine tin your self.
Love that rear heater outlet setup. Very clean!
One consideration: usually cyl 3&6 (2 at rear) run slightly hotter not sure if pulling air off at those 2 points will make things worse? |
The 964 uses a piece of stainless tubing for the air crossover, so the P engineers must have had so me reason to spec a cast piece for the 993. Extra heat in that area compared to the 964?
A 964 uses a similar exhaust as an SC or Carrera, the exhaust wraps around the back of the engine, combines at a crossover pipe, and the cat runs along the exhaust valve cover on the driver's side. A 993 has a true dual exhaust with a crossover section at the front of the engine with 2 cats right below that cast part. So there is significantly more heat there on a stock car. |
"I would think that it would help. You are forcing air past an area where it would normally hang around."
I was thinking the same thing...hmmm I wonder if it would be something to consider for earlier 911s? |
I bought this piece from Patrick motorsports. It should work for me, although it won't be the cleanest install. I will use SCAT hoses, but the v-ram intake interferes. It will be tight...
I have the big cast aluminum manifold as well, but it am using the older engine mount with an m&k muffler, all bolted up to stock 993 heat exchangers. The muffler doesn't leave room for anything else back behind the bumper... http://img.tapatalk.com/d/14/03/12/erysu9ed.jpg http://img.tapatalk.com/d/14/03/12/ba8a9ate.jpg http://img.tapatalk.com/d/14/03/12/5uraveda.jpg |
Also still working on the exact plumbing with silicon reducers, couplers, etc.
http://www.siliconeintakes.com/index.php?cPath=14&osCsid=05d2cf8f9cb4e52ed62ba355 d0b878f3 http://img.tapatalk.com/d/14/03/12/4e9atyma.jpg |
| All times are GMT -8. The time now is 06:52 PM. |
