Engine ID help
I have acquired at my shop a complete engine with mfi. It came out of a very rough 1973 car that was stored for over 20 years. The car is long gone. The engine serial number is 6668025. Would appreciate help identifying what we have here.
Old 03-09-2014, 08:07 PM
RaketeRot
Draden's Avatar
Dude if that case is stamped 930/02 and is aluminum. That's a 1976 930 case. Originally a 1976 carrera engine. Head if original are 49/41.5 valves and 39/35 ports. Check for the 930/02 and look at the heads for part numbers see if they are still there.
1967 911R hybrid clone
1973 911 RSR - coilovers, 2.8L twin plug RSR cam engine. butt welded metal RSR flares and metal frame ducktail
If it were easy, it would not require people of our caliber.
Old 03-09-2014, 09:10 PM
RaketeRot
Draden's Avatar
It was a lighter CIS engine with the 2.7 crank and 930 case. No turbo but all 930/02 came with Mahler nikasil cylinders too. If intact and running you've got something real nice there. Just the case alone. Heads alone and or cylinders alone are bucks. Can you say high rev short stroke 2.8 or 3.0 rebuild? Cool if intact
Old 03-09-2014, 09:16 PM
RaketeRot
Draden's Avatar
Check the case stamp and check the part numbers on any part that has markings
Old 03-09-2014, 09:18 PM
I forgot to mention the car was a euro spec 911. Car apparently was raced, to what degree or where was not known. The car(with motor)was imported directly from Europe to US, so this motor was never a US smog version. I'm not sure if the euro 930 were MFI. Will check numbers in the next day or so. Appreciate the info so far!
Old 03-09-2014, 09:50 PM
The fourth digit, "8", does not fall within the range of engines that I could find. The 76 3.0 Euro carrera had a range from 6660001-6661385. Are you certain the fourth digit is an 8? If so, it's possible it's a replacement case.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 03-10-2014, 07:42 AM
Id
I'll recheck that number again. Thanks.
Old 03-10-2014, 08:03 AM
Id
Thanks for the help. Everything checks. We've got one more ID question for this forum. Pulled out of long term storage a motor (no car) with mfi with the serial number 6321711. Appreciate help in IDing this one as well.
Thanks!
Old 03-13-2014, 08:47 AM
Thanks!
6321711
Decodes to a 1972 S engine, series number 1711
Look for engine type stamp 911/53. 190 hp MFI injected engine
Nice find!
L.J.
Old 03-13-2014, 08:57 AM
gearhead
If you want to sell Speedo has been looking for a '72 S engine for a while now.
On the 3 liter what's the number on the MFI pump. If you have a real 3 liter pump, and not a conversion, the pump alone is worth more than a complete 911sc 3 liter engine.
Old 03-13-2014, 11:20 AM
Id
Pump number you asked about:
Ser. 13108659 0408 126 019
Distributor on the 72 s motor 0231 169 005 JFUD 6
Have not gone back and checked the case on the 72 if its 911/53.
Old 03-14-2014, 02:36 PM
pors1968's Avatar
That a nice MFI pump 019 RS
Old 03-14-2014, 04:08 PM
Id
What year is this for?
Old 03-14-2014, 05:52 PM
gearhead
I think he's saying '73 RS. Not RSR valuable but still worth a lot. Suggests your whole mfi may be original RS. I'd get casting numbers off the manifolds next. Pictures would be great too.
Old 03-14-2014, 06:14 PM
911 110 312 R
Heads...911 104 307 R 2-72 5K 1819H
Old 03-14-2014, 06:41 PM
911 110 312 R
I got to clean things for pics. Maybe later.
A question again about the mfi pumps. Are the last three numbers the indicator (019) of 73 RS pump or the numbers that preceded it.
Thanks!
Old 03-14-2014, 06:46 PM
pors1968's Avatar
heads 70-73 S same as 73RS as the date 2-72 now you have mfi pump 019 73RS the heads.
Old 03-14-2014, 07:18 PM
Update... did a quick look at the 72 S case. Could not find the 911/53 that ossiblue mentioned. Got this number
901 101 102 4 R
What does that, if anything, tell us?
Old 03-22-2014, 11:19 AM
pors1968's Avatar
This is one side what is the other side. It should 901 101 102 3R if it 72
Old 03-22-2014, 11:22 AM
haycait911's Avatar
901 101 102 4 R
look here for the type number...
Old 03-22-2014, 11:45 AM
