Ok, this all started with a broken head stud and oh look, I can see the top of the rear shock nuts, now that the engine is out. Guess I had better replace them. Although, I have to admit that the original Boges, even with only 17K miles, are pretty soggy compared to the new Bilsteins.
I noticed that the lower rear shock bolts have a red substance on the threads. Given the effort required to remove these, I assume that it's red Loctite. Should this be used again on reinstallation or should I just clean up the threads and reinstall dry?
John Last edited by rzepko6194; 03-18-2004 at 09:38 AM.. |
I think you're looking at a red paint mark from the factory which likely indicates the fastening was "complete" or the proper amount of bolt rotation ( indicating torque) was applied....not loctite
---Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
No, it's not the red paint mark on the bolt head. It's reddish-pink stuff on the actual threaded part of the bolt. It was fairly tough stuff to wire brush off.
John |
Friend of Warren
I don't use loctite. Actually I use antisieze on the threads to make sure I can get the bolts out later. Those steel bolts going into aluminum threads can almost guarantee that they will lock tight all on their own.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I did the same as Kurt with antisieze.
Current: 07 S4 Avant, 06 Volvo S60R Sold: '74 911, 01 986, 93 Volvo 240 |
Thanks guys.
John |
Loctite does not retain it's color when cured.
I believe you screw the bolt into a captured steel threaded insert that is in the aluminum banana arm. I don't believe Loctite was used...but may have it from the actions of a previous owner?
---Wil Ferch
John Last edited by rzepko6194; 03-19-2004 at 09:46 AM.. |
Schleprock
Most of the antiseize that i've seen Porsche use is the copper stuff.
The lower shock bolts are typically stubborn. I agree that Loctite was probably not used, but you never know. I know the factory didn't use it because my microfiche repair manual states the torque specs and any antiseize or threadlocker needed for any fasteners. No Loctite that I can remember mentioned in my fiche.
Kevin L '86 Carrera "Larry" |
Use antisieze and torque to spec (95lbs?). Those bolts are so long that red or even blue loctite would make it very hard to loosen.
