Alternator ID
Hello everyone,
My alternator on my '78 SC went out yesterday while cruising at lunch. I heard a different sound from the engine bay, stopped and found the 11 blade fan wobbling and making noise and then the alternator light came on in the dashboard and my volt meter dropped down to just under 12V. I pulled the alternator out today and found the black plastic cap that centers the rear bearing very brittle and broken (you can see in the picture). Wiggling the shaft produced obvious play between the bearing and the alternator housing. It looks like the brushes are worn very unevenly (no, one is not stuck) So, if I may ask those of you who have worked on these before. Do you know which alternator this is? I thought only the '74 had replaceable brushes....not sure on that though. I don't see any labels or markings to indicate brand/model on this. I don't mind ordering a new/rebuilt unit from our host, but don't want to get the wrong one. Thank you, Phil ![]() ![]()
Phil 1978 911 SC |
Thats a Motorola for the 78.
Bruce |
ROW '78 911 Targa
Alternator ID
Looks identical (other than the dirt) to my '78's 70 amp SEV Marchal.
Send it to a good rebuilder as they are NLA.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 03-16-2014 at 12:04 AM.. Reason: Wrong amperage. Alignment too! |
Before I turn to 'The Google', does anyone have a good rebuild experience with an alternator shop? I've never sent one out before.
Phil 1978 911 SC |
diode plates, i.e. the originals used diode plates with soldered diodes (better for heat dissipation). Note: See the first pic as that alt was an original & non-rebuilt using the original diode plates. Last edited by mysocal911; 03-15-2014 at 06:29 PM.. |
ROW '78 911 Targa
I guess the rebuild won't last as long as the originals did. Alternator was rebuilt before I bought the car.
