72' 911S
leadrsa729's Avatar
Send a message via Yahoo to leadrsa729
Shaking Clutch Pedal
Hi -
I have a 72' 911, and at idle the clutch pedal vibrates enough to make a noise against the wooden plate. The clutch cable is adjusted properly with the correct amount of travel to it so I'm wondering how this is adjusted. Is it the nut at the end of the clutch cable nearest the pedal cluster, or am I looking at possibly replacing the bushings in the pedal cluster as well to tighten things up?
Thanks in advance!
Old 03-11-2014, 07:33 PM
72' 911S
leadrsa729's Avatar
Bump....
Old 03-12-2014, 08:53 AM
tharbert's Avatar
I think, if you pull the floorboard off and look at your pedal assembly, you'll find a broken/exhausted return spring.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 03-12-2014, 09:07 AM
tharbert's Avatar
...or other issues therein. It's not hard to rebuild these. It's one of Wayne's 101 projects for your 911.
72 911T 2.4 MFI
Old 03-12-2014, 09:10 AM
