Wheel/Tire size quesions
Hello all,
I just picked up another 911 (makes three!). It is a 1980sc targa with a steel wide body and it currently has beautiful original condition gotti wheels with 225/50/15's and 345/35/15 (not a typo). However, I do not love the wheels nor the idea of replacing the rear tires so am looking to move to a new set up (fuchs). Naturally I have a lot of space to fill and having more background with newer vehicles, having a good stance with full fenders is important to me (not 'hella flush' or anything like that, just a good fit). This was not an expensive car so anything OEM is out which leaves me with replica wheels like euromeister. Are there any other wheels I should be considering? Also, I have ZERO idea what tire sizes to run. The 16x9's recommend a 245/45/16 which is basically non-existent so can I run a wider tire with narrower side wall or just a wider tire? Further, for the fronts can I run an 8" wheel and if so what tire size? The Gotti's up front do not come close to filling the fender well. Thank you for all the helpful advice that will undoubtedly be contributed! ![]() ![]()
up front stickt to 7x16 205/55 and 7mm spacer
rear: i'd say 9x16 or even 10x16 with 30-60mm spacers at your own gusto.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
What about the Rota Fox 7.5 and 9x17s? You could run 235s/275s with some spacers and fill out the wheel wells pretty well.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
the 17* rota are "nice" fuchs-replica option... no?
Good luck.
Could I run a 255/50/16 our back on a 9" wheel and have it look correct (subjective term, I know)?
I've run 275/40-17s a lot. They are 25.6" diameter and I think they look "big", but they fill out the wheelwells nicely on SC flares. You looking to fill much bigger "shoes"...
MBruns for President
tougher on flared cars.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Jeremy,
That is one sick ride......nice. Scott
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
judging from the PM's ~ Guess I should have said more -
They are Zuffenhaus Wheels - 9 x 17 and 11 x 17 They are -8 ET on the rears and 17 ET on the front - 255/40/17 and 315/35/17 Anything under a 17 and you will have to go with a Michelin TB or cut up some hoosiers with treads - or just run R6 Hoosiers on the street like outlaw Magnus Walker... I have a set of Fikse wheels for the track - same offsets and same tire sizes - although the next set of NT01's I'll probably size up the fronts to 275's. I like the old school looks with the gold - I understand not for everybody... ![]() ![]()
weren't you also using 4mm spacers in front?
Yes, good memory Mr. Verburg
