maresdesign's Avatar
Winter project - Oil leaks and clutch
Since my car is a dedicated fair-weather vehicle (speedster) I thought I'd tackle some long over due projects. I've replaced all the seals that can be replaced with the motor in the car, but now time to drop the motor and get to them all. The car is a 71 911E Targa, now speedster, with a leaky tranny and motor.
Too much grime!
The trans unbolted and separated from the motor so I knew then it was swapped from another 911.
Old 02-11-2014, 11:51 AM
Leaking tranny seal
Leaking main seal
Worn clutch and fllywheel
Old 02-11-2014, 11:56 AM
Drain the tranny
Four cans of carb-cleaner later
Old 02-11-2014, 12:00 PM
Leaking pulley seal
Pulled oil cooler - leaking seals.
First shipment of seals. PVC pipe adapter to install the main seal. Also clutch lever and throw out bearing bushing parts and flywheel.
Old 02-11-2014, 12:05 PM
New main seal installed. Used Curl-T sealant.
Pulled chain covers to check tensioners and ramps. Tensioners have been modified as to be a "fixed" type. Since there was no rattling sounds or otherwise I buttoned it back up with new seals.
Old 02-11-2014, 12:13 PM
New flywheel bolts to install the new flywheel. I recommend using a brand new tool for the bolts and take your time torquing to spec.
I found another leak. This mystery paper gasket was installed along with the rings to seal the oil sender at the back of the motor. Replaced with new sealing rings and torqued to spec.
Also replaced the intermediate shaft cover seal while i had access.
Old 02-11-2014, 12:21 PM
New clutch kit! Replaced everything but the lever. Including the main seal behind the lever/throwout bearing assembly. I used the quid tube as the seal installation tool, just tightened it slowly while watching the seal get pushed in. Easy.
Old 02-11-2014, 12:26 PM
I thought since the motor was out I'd detail it a bit.
Found a leak at the oil tank filler neck tube. It had cracked and leaked oil vapor everywhere. It was hard to see until the motor was out.
New Filler neck tube/hose
Old 02-11-2014, 12:31 PM
Here's a tricky leak to spot. The speedometer drive seals. There is a large oil ring, a sealing washer and mini-main seal (for the lack of a better term) You've got to remove the assembly from the tranny and take it apart to get to the seal. I don't have pics of the process but it was quite a pain to remove the old washer and seal. Don't forget the sealing washer on the bolt that keeps in inside the tranny.
New clutch and pressure plate installed.
and a pic of everything replaced so far
Old 02-11-2014, 12:38 PM
Tranny reunited with the motor.
To be continued...
Old 02-11-2014, 12:49 PM
Forgot to show this pic. Using the guide throwout bearing guide tube to insert new tranny main seal.
Old 02-11-2014, 12:56 PM
Projekt Rostlaube
june82000's Avatar
Looks wayyyyy better! Very informative, great pics also - Thanks!
Old 02-11-2014, 01:07 PM
Hope you used the special high temp grease on the tranny input shaft. That is some important grease!!
Old 02-11-2014, 02:34 PM
The grease was included in the Sachs clutch kit.
Old 02-11-2014, 02:38 PM
911SC Tinkerer
merlinfe's Avatar
Thanks for the great pictures!
Old 02-11-2014, 03:51 PM
steely's Avatar
Really! - great job and thanks for the porn!
Kills the winter doldrums.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 02-11-2014, 07:40 PM
Discseven's Avatar
Nice job & post MARES!!!!!!
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 02-12-2014, 02:06 PM
Getting excited for Spring...can't wait to get it back on the road. With no more leaks! Here's some more pics:
Early 911 Speedster or is it a Spyder?
Saving up for new tires.
Old 03-12-2014, 07:40 PM
