Vintage Motorsport
RichardNew's Avatar
Different Cage Design
This is from this morning at Sebring. I don't think I've seen this type of side impact bar used before. It's most likely an FIA requirement.
Richard Newton
The Tech Blog
Old 03-13-2014, 02:12 PM
Jnikic's Avatar
Looks like a gussetted x bar that extends out slightly into a gutted door. Its often used on the driver's side to provide more distance between the drive and the cage. The bar running vertically from the floor to the upright is what's called an FIA bar, helps enormously in rollovers (started in rally, I believe).
78 911 Coupe :: E Prepared racecar :: Stock 3.0 :: Steel widebody :: 930 brakes
78 911 Targa RSR backdate :: 3.2L :: 10.5:1 Wossner pistons / Mahle cylinders :: Twin plug crankfire ignition :: 46mm PMO
Old 03-13-2014, 03:12 PM
Wer bremst verliert
JohnJL's Avatar
I don't see the x-piece as new, my old car has that.
I do find the A pillar area unusual and interesting.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-13-2014, 04:42 PM
Vintage Motorsport
RichardNew's Avatar
What seems to be new is how they extended the X-piece out into the door cavity.
Richard Newton
Old 03-14-2014, 03:51 AM
cycling has-been
bkreigsr's Avatar
Is that one of the factory team cars?
Bill K
Old 03-14-2014, 07:04 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Makes sense to "expand" the X into the door cavity for a couple of reasons
1. Obviously provides more clearance from the roof line for the driver to exit. For those who don't know, most regs require the driver to be able to exit from driver AND passenger side of the car.
2. In an impact, the bowed X frame is stronger than the flat X frame.
I'm guessing that extra bar along the A-pillar is to make up for the lack of the typical crossbar that joins the uprights across the dashboard, often called a "kneebreaker bar?"
Kevin L
'86 Carrera "Larry"
Old 03-14-2014, 08:17 AM
OffCamber00's Avatar
Bill K
Yep. Porsche North America (Core Autosport)
Mat P
1988 911 Carrera
Old 03-14-2014, 08:31 AM
Cory M's Avatar
They started doing that on the driver side of the 996 cups, been like that for years. The vertical bar is a new addition but has been used by many other manufacturers for a while (especially in rally). As the windshields get leaned back for better aero they need more support in case of a rollover.
Old 03-14-2014, 09:07 AM
Cory M's Avatar
That's not Core. Core is running the RSR's and the cars and livery's are very different. That looks like a 991 "GT America" cup.
Old 03-14-2014, 09:09 AM
Cory M's Avatar
Here's the standard cup "GT America" on the left, and the Core factory RSR on the right. Note that the RSR is significantly wider, has different aero, through hood cooling, quarter panel vents, etc.
Old 03-14-2014, 09:14 AM
porsher
aston@ultrasw.c's Avatar
The clever part is the straight tubes and two triangulated halves.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 03-14-2014, 12:04 PM
Wer bremst verliert
JohnJL's Avatar
interesting differences between the splitters. i am guessing the rsr is what you do with fewer or no aero restrictions?
Old 03-14-2014, 03:33 PM
