Blinker/Wiper update
For those new to my thread, I recently upgrades my battery and had a cut-off switch added to it. Now when I turn on my blinkers, the wipers come on. The wipers work fine by itself. I have researched parts based on suggestions, and have found "turn signal switches" for around 120 dollars, and "relay turn signal switch" for about 20 dollars. I' m really not sure if either one will fix my problem.....Has anyone had a similar situation? Please advise!!!
Old 03-14-2014, 04:00 AM
wolds's Avatar
Just a suggestion. Don't start a second thread regarding your issue. Also before spending money on non returnable parts determine which part is at fault. I suggested in your previous thread that you pull the wiper switch and turn signal switch out of the circuit as a way to determine if they are at fault. No out of pocket expense for using this tactic. Someone else posted that it could be a ground issue. I agree with this logic as circuits can back feed in an attempt to find ground through another component on the same circuit. Try investigating this. Warren
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 03-15-2014, 08:50 AM
