upper shock bushing installation
was in the process of replacing sticky front calipers and renewing shock inserts- right side went without a hitch- shock insert on left side, however, had welded itself to upper bushing- only alternative was to pry out the insert from below, which brought bushing with it- have completed my brake work and have installed new shock insert but cant seem to find any way to coax/push/force bushing back into mounting plate- do I need to remove mounting plate and have bushing pressed??
figure I will need to replace bushing since rubber is freeing itself from steel center- next question will obviously be how to get the bushing out of the right side when I go to re-do that one?- thanks guys
Old 03-18-2014, 09:21 AM
Cory M's Avatar
would something like this work?
Strut Mount Bushing (pr), Poly Graphite, 911 & all 914 (1965-89)
Old 03-18-2014, 10:39 AM
it is the installation which is my problem- but that is the bushing, alright
Old 03-18-2014, 12:36 PM
Cory M's Avatar
the bushing I linked is split, so you don't have to try to force it back in place like the old one..
Old 03-18-2014, 12:53 PM
air+fuel+spark
combatic's Avatar
ER also has solution/s depending on what you want for suspension. I watched a replacement video and the solution for removal was to cut the camber plate bushing flange...so I cant imagine install can be done without a special press....
ER Rubber Camber Plate Bushing
bryan
1969 911T , '04 S2000, '96 900SS, 4x4 urban assault vehicle
R Gruppe #653
Old 03-18-2014, 02:31 PM
thanks guys- was completely oblivious to split bushing- easy, easy- parts on order
Old 03-18-2014, 03:02 PM
