Valve Adjustment Cost
What is the typical shop cost for a valve adjustment?
I know, I know, I should be doing it myself, but I'm traveling 7 out of the next 9 weeks, and I simply don't have time to do it. Thanks!
Michael '98 Boxster in Ocean Jade Metallic |
one of gods prototypes
i would say 400-600 depending on the shop doing it, make sure the tech knows air-cooled porsche engines
Brought to you by Carl's Jr. |
How long does it take for a pro to do it, or how much do they charge?
Sorry to bring it up, but that's one of the annoying things about "book rates", especially on maintenance items.
Neil '73 911S targa |
It's a 3ish hour job here in VA, so that comes to about $200, plus $30 something for the gaskets/nuts. Maybe add $30 for the oil change. I've never paid more than $250.
George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS |
Should be cheaper than that.
I recently started doing it myself, but prevously paid $331.00 valve adjust and alternator belt, I supplied the oil and filter. It's usually ~2 hours labor plus parts and oil. After doing it myself it's money well spent. Took me all day the first time, should be able to get it down to 4 hours next time. But I changed the plug wires, checked the compression and cleaned all the black gasket sealer off the heads and valve covers someone in the past had put on there.
jwill911 Espresso brown metallic `87 Carrera Coupe (sold) Now living in Mississippi |
Somewhere in the Midwest
When I was in college at FSU (Tallahasse, FL for those that never here of Bobby Bowden), there was a shop called Eurosport (I think..college was a bit hazy) that I took my car too. I was broke and looked the part too so they may have taken it easy on my, but they charged me about $200 for a valve adjustment (I think). If anyone is in the area, check them out. They were always good to me. I hope they are still there (in a hidden industrial part of the town).
2 hours ($160) at my shop, plus gaskets, oil and filter.
Senior Member
When I got rid of the CAT and backdated the exhaust, backdated the heater hose routing, changed oil lines and removed the A/C, I cut the length of this job in HALF AT LEAST!!!! I cannot overstress this. With those parts out of the way, it is a pretty quick job. With them in the way, it is most of a day.
Next step is an air compressor and one of those air ratchet-shaped things. That'll reduce by another 15 minutes.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Senior Member
One thing to remember is that the motor has to be absolutely cold when the valves are adjusted, so bringing it in the night before and picking it up the next day is not a bad idea. Sure makes the mechanics happier as they can drain the oil overnight and not have to mess with playing around with warm motors.
Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Wanna move to Florida John???????
