Super Moderator
cstreit's Avatar
What coil with MSD ignition?
Guys,
What coils can I use with an MSD ignition system?
I see that MSD offers one, but I'm hoping there's another alternative...
Is there a specific rating necessary on the coil?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 09-11-2002, 08:55 AM
Chuck Moreland's Avatar
I've seen statements from MSD that say you must use their coil. But I've installed a 6A ignition with a Bosch coil, as well as the MSD coil and both seemed to work fine.
If you go with the MSD coil, get the high vibration version. It is rated for mounting in the non-upright position so you can use it in the factory bracket. If you take of the MSD sticker it looks discretely like any other black coil.
Chuck Moreland - elephantracing.com - vonnen.com
Old 09-11-2002, 09:01 AM
Super Moderator
cstreit's Avatar
Is there a substantial difference between the stock Bosch coil and the Blue coil? Wil I be missing anything significant (granted it's only $30...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 09-11-2002, 09:38 AM
MSD lists coils that are compatible and the Bosch blue is on the list.
Joe Riley
84 Carrera Targa
69 911S Coupe
Click here for 911S project "updating as I go"
Old 09-11-2002, 09:46 AM
jabb's Avatar
This is the Coil I am using.........
MSD SS Blaster Coil
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 09-11-2002, 09:58 AM
Super Moderator
cstreit's Avatar
How much is that coil Joe? Any particular reason you selected that over the Bosch blue?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 09-11-2002, 10:00 AM
304065's Avatar
Porsche Crest Coil
Chris,
I use an MSD Blaster "High Vibration" coil with my 6AL. They also sell a plastic coil wire hold-down to keep the wire in there no matter what.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-11-2002, 10:15 AM
jabb's Avatar
Chris:
I used it in my 914/6 so it gave me the ability mount where ever and However I needed to mount it and it is not very large fits in the palm of your hand. It also has nice rubber mounting points for anti- vibration . The cost was about $40
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 09-11-2002, 10:17 AM
I was told that those "hot" MSD coils are a good plan (in conjunction with the MSD unit). They provide 40k volts and will do so throughout the rev range. I'm told the Bosch coils will not do this. This allows one to gap the plugs at .05 which, supposedly, gives a larger spark for better flame propagation....just requrgitating the advice I was given for my carbed engine, here.
In actual practice, it works GREAT !!
I used the high vibration thingy.
I can now drive the car around at 2500 rpm (or less) without fouling plugs.....not that it's any fun It will also sit and idle at 1K without fouling. Starting it after sitting for a couple weeks is a bit of a trial but it's mo better. If started daily, it lights right off.
JPIII
Early Boxster
Old 09-11-2002, 12:22 PM
Super Moderator
cstreit's Avatar
So where do I get one? Any place by mail order that you recommend... DOn't see them on PelParts...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 09-11-2002, 01:55 PM
jkeyzer's Avatar
Summit Racing should have what you need. I bought my MSD and high vibration coil from them.
http://www.summitracing.com
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 09-11-2002, 01:59 PM
Super Moderator
cstreit's Avatar
Wayne,
I'll Pelican then when I decide. Thanks!
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 09-11-2002, 02:37 PM
CamB's Avatar
I was advised to go with the High Vibration One as well. Its cheap enough and worked fine.
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 09-11-2002, 02:43 PM
