I installed a set of the whites. Great upgrade. Thank you.
Here is an excellent write-up with pictures from the install from Pstallo.
http://forums.pelicanparts.com/porsche-911-technical-forum/809742-led-gauge-tutorial.html http://forums.pelicanparts.com/uploa...1399345105.jpg Thanks for posting it. Engelbert |
The LEDs work great, BTW! I feel like I'm back in the modern age when I turn the lights on!
Installed these this AM
25 minutes start to finish, didn't need to remove the steering wheel but the tach was a tight squeeze. The difference is literally night and day. Just a few things...
I need to figure out why my high beam indicator isn't working, but it wasn't working when I started either. One of the instrument lights in the fuel gauge wasn't a BA7, so I re-used the existing bulb and added the LED to the other socket, still looks great. Two thumbs up!! |
Did you take a picture of the socket in the fuel gauge ? Would be good to know what other type of bulbs are in there. I which other socket did you use the LED ? Thanks Engelbert |
LED Turn Signal Indicator bulbs ????
Are turn signal indicator bulbs available in LED yet (for a '78 SC)?
I am going to order a LED set, but the faint turn signal indicator is the light I DONT SEE the most & I would love to have fixed. My loud muffler (& no insulation pad) means that I dont hear the turn clicker either. Peter 78 3.0 SC http://www.bytephoto.com/photopost/d...edium/bulb.jpg |
In a huge thread on LEDs I found this post.
A PM to one of these guys that have researched dash lights may provide the answer for you. |
Since I already had you soft-white set, which installed and worked perfectly TY, (I only have one bulb and a need for one spacer in my clock, is that odd?), so I got two green signal LEDs from Jake. I removed the old signal bulbs and plugged in the green LEDs. They didn't light up on either side yet I heard the signal stat clicking. Flip the bulbs over in the socket and they light up all the time, move the lever to signal left and the right signal blinks brighter (but is never off) Signal right, same thing. Put the oem bulbs back, works perfectly. Any ideas? |
I R an idiot. The "oddball" bulb is the low fuel indicator. |
http://airboxer.com/images/LED_green_Blue.jpg I hope to get them test before the end of this week. Cheers Engelbert |
Cheers Engelbert |
I will take a look what's in my SC, but I thought they are BA7s. Cheers Engelbert |
I did not get a round to remove the Tach, since I have to remove the steering wheel to get it out. However, I measured the holes on a spare Tach I got. And the holes from the turn signal indicator are smaller. See picture below, the Illumination and High beam indicator are 9.9mm for the BA7s sockets, and the turn signal holes are 9.6mm.
I found out that bulb type is W2x4,6d and they are all over at ebay, however, I have no experience with them, and I don't know if they work with the turning signal. Here is a picture of the Tach: http://airboxer.com/images/SC-Carrera_Tach.jpg Cheers Engelbert |
Aside from me dropping an old bulb into my speedo I am very pleased with these lights. They are hilariously bright compared to the originals. I initially did just the speedo and in daylight in my garage I could easily see the illumination in that gauge whereas with the others you could not tell when the lights were on or off. Good deal.
Ps. The vintage colour is very fitting as well. |
Did you get the old bulb out ? Cheers Engelbert |
Just want to post some feedback I got on my LED's:
"This weekend I put in your Vintage White LED's. My preference is for the White LED's but I wanted to try the Vintage first as I was unsure of how fragile the LED's might be with my heavy handed installation technique. Everything working a charm. I did not take a picture of the LED's from the alternative source, but I can tell you, yours are much brighter, and have a slide wider dimming range. I will put the white ones in due course. Here are a couple of pictures taken in a moderately sunlight garage." http://airboxer.com/images/LED-Installed01.jpg http://airboxer.com/images/LED-Installed02.jpg Cheers Engelbert |
I had a few questions regarding how to point the LED's during install.
I made up this little graphic, that shows how to point the LED's, so that the side LED's give the best light. Basically the side LED's point 90 deg to the outside wall of the instrument. Example on the clock is the only one light at 12h so the side LED's should point left and right. http://airboxer.com/images/pointing_LED.jpg Cheers Engelbert |
Nice work engelbert I will be ordering shortly
When I go to your website and click order the only option is for "bright white" so do you still offer "vintage white" sets?
Thanks! David |
Otherwise PM me. Thanks Engelbert |
I still have both types available, Bright White and Vintage White.
http://airboxer.com/images/All_White_01.jpg http://airboxer.com/images/All_Warm_White_01.jpg Cheers Engelbert |
Just want to post some feedback I got from a buyer in Australia.
HI ENGELBERT, THE LED’S ARRIVED YESTERDAY ALL WELL AND GOOD. I TESTED THEM LAST NIGHT ON MY SPEEDO AS I CURRENTLY HAVE ALL THE GAUGES OUT DOING A REFURBISHMENT ON THEM. THEY ARE ABSOLUTELY BRILLIANT……THE DIFFERENCE IS LITERALLY LIKE NIGHT AND DAY……I CAN FINALLY SEE WHAT SPEED I AM DOING AT A GLANCE INSTEAD OF HAVING TO SQUINT AND LOOK FOR THE NEEDLE. ACTUALLY , I HAD ALREADY INSTALLED EL WIRE AROUND THE INSIDE PERIMETER OF MY GAUGES AND IN MY OPINION IS THE BEST WAY OF ILLUMINATING THESE GAUGES , I LOVE THE WAY YOU GET A TOTALLY EVEN DISTRIBUTION OF LIGHT ACROSS THE FACE OF THE GAUGE WITHOUT ANY SHADOWING. HOWERVER , IT WAS A TEDIOUS , FIDDLY AND TIME CONSUMING JOB HAVING TO UNCRIMP THE OUTSIDE BEZZEL , TAKE THE INSIDE OF THE GAUGE TOTALLY APART THEN RECRIMP AND PAINT THE BEZZEL WITHOUT DEFORMING IT. IF ANYTHING EVER GOES WRONG WITH THE EL WIRE INSIDE THE GAUGES I WILL NOT BE REDOING THEM NOW THAT I HAVE YOUR LED’S. IN FACT I WILL BE RUNNING BOTH SYSTEMS SO I CAN JUST SWITCH BETWEEN THE TWO WHEN DESIRED. ONCE AGAIN THANKYOU FOR A GREAT PRODUCT AND HOPE TO GET YOU A FEW MORE SALES “DOWN UNDER” AFTER SOME FRIENDS SEE THE RESULTS. Cheers Engelbert |
Ordered a set, looking forward to seeing the light. Great work.
Yes, they are dimm, see the video Kevin did after instaling them in his 914.
<iframe width="560" height="315" src="//www.youtube.com/embed/kF3Uz8gjGWM?rel=0" frameborder="0" allowfullscreen></iframe> It works in my car as well. Cheers Engelbert |
Rothaus I sent you an email over the weekend from your wevbsite about placing an order did you get it?
Just sent you a PM
Cheers Engelbert |
New LEDs installed. Just wanted to say, finally had the chance to install the set from Engelbert, including blue and green - WOW, I can SEEEEE!
Very cool, and no issues installing them either (less fighting to get one old one out of the back of the gauge). Let the night fall I say! Thanks Engelbert and well done. |
Thanks for the good feedback SmileWavy
I'm glad they worked out as expected. I also opened a Feedback thread for any questions, comments, tips, suggestions, etc.. http://forums.pelicanparts.com/porsche-911-technical-forum/823546-post-here-your-experience-new-gauge-ba7s-led.html Thanks Engelbert |
LED Gauge lights
Just want to let you know, I still have the bright white and vintage white BA7s Dash LED lights available, as well the red and green for the High beam and parking light indicator.
I will soon have a set for testing for the 964 / 993 gauges. Cheers Engelbert |
Clock LED Comparison
I purchased the Etarga LED kit and have been very happy with it but the clock always left a lot to be desired. No fault of the LED but the design of the lighting for the clock itself with only one bulb to light the entire gauge.
Englebert was nice enough to sell me just the bulb for the clock which as I figured it was worth a side by side comparison. He included the spacer since these bulbs are twice as long and a foil if necessary (I didn't need to use it). Attached are four shots, two direct head on and two from the side. There seems to be a little difference head on with a slight advantage to these bulbs. From the side because you do see the refraction throughout the entire gauge it is much more noticeable to the eye even though the picture makes it look brighter but slightly washed out. I'm purposely not saying which is which in order to not to insert subjectivity to it, and forgive the fact it's not the low light capability on the phone is not so great. http://forums.pelicanparts.com/uploa...1413847601.jpg http://forums.pelicanparts.com/uploa...1413847733.jpg http://forums.pelicanparts.com/uploa...1413847764.jpg http://forums.pelicanparts.com/uploa...1413847783.jpg |
I just got Engelbert's LED lights and wow!! I can see!! What a great upgrade for very reasonable price!! The difference is like night and day. Shipping was super fast as well. Have to agree with TAG about the clock needing another light though.
http://forums.pelicanparts.com/uploa...1414076919.jpg http://forums.pelicanparts.com/uploa...1414076938.jpg |
Thanks for the feedback SmileWavy
I know the clock is the most difficult instrument to illuminate, did you try to rotate the LED ? The Bulb in the clock is at the 12h position, and the LED work best when they point left and right, and the spacer is needed. http://airboxer.com/images/pointing_LED.jpg Your gauges look the same as mine in the SC. Cheers Engelbert |
Engelbert,
No, I have not rotated the LED yet. Thanks for info. I will try that tomorrow. This is not fault of your LED at all though. I think it just needs one more light in the bottom. I agree that you need the spacer for the clock. Without it, it does not illuminate at all. Hiro |
Just ordered a set of vintage 911 + B & G from you.
Look forward to getting a big lighting upgrade! Thanks for making these available. Best, Lars |
| All times are GMT -8. The time now is 12:03 AM. |
