-   -   Testing some Instrument LED (http://forums.pelicanparts.com/porsche-911-technical-forum/802807-testing-some-instrument-led.html)
rothaus 03-24-2014 05:56 PM
I installed a while ago in my SC a set of LED from Superbright. That was not bad for about $1.5 a bulb.
I also noticed a lot of postings about LED's which are much brighter then the SB once.
I did some testing to compare some of the bulbs out there.
Here is what I used.
No. 1 is the standard bulb which work with the dimmer.
No. 2 is the Superbright which is not bad, About $1.5 each, but they don't work with the dimmer.
No. 3 I found on Ebay Germany EUR 3.5o - these work with the dimmer
No. 4 New design with 3 small LED on top and 1 LED left and right. These work with the dimmer and light up the most difficult instrument, the clock, since it has the only one bulb on top.
http://airboxer.com/images/LED-Test.jpg
Here is a picture with the clock and the Speedometer with the original bulbs.
http://airboxer.com/images/tach-clock-st-bulb.jpg
This is with the Speedo with the SB LED and the clock with the standard bulb
http://airboxer.com/images/tach-SB-L...ck-st-bulb.jpg
Here an other angle
http://airboxer.com/images/tach-SB-L...-st-bulb-2.jpg
This is the LED from German ebay, the clock still on standard bulb.
http://airboxer.com/images/tach-EBAY...ck-st-bulb.jpg
This in the new LED set on the dimmer low
http://airboxer.com/images/tach-NEW-...bulb-dimlo.jpg
and here on dimmer high
http://airboxer.com/images/tach-NEW-...bulb-dimhi.jpg
Now this one is with the clock installed with the new LED.
http://airboxer.com/images/tach-NEW-...-LED-dimhi.jpg
tirwin 03-24-2014 06:05 PM
Nice!
Where did you find #4?
wwest 03-25-2014 09:19 AM
Some of the instrument uses have a depth limit which would prohibit the use of #4.
rothaus 03-25-2014 09:37 AM
Originally Posted by tirwin (Post 7978711)
Nice!
I got the #4 LED.
I would make 2 set's available for testing, if somebody is interested.
The Clock is short on space, and need a spacer to set the LED at the right depth.
poorsha 03-25-2014 09:55 AM
Great stuff.
I need to follow this.
nineball 03-25-2014 12:38 PM
i would be interested in your other set of the #4 leds (depending on cost). my lights currently suck.
rothaus 03-25-2014 01:03 PM
The test set is free, I have one left.
PM me your mailing address, and I send it to you.
poorsha 03-25-2014 04:06 PM
Nice!
Ditto
armand80sc 03-25-2014 04:13 PM
I just had a look at the ultimate LED thread here on Pelican - lot of stuff there.
Etarga's LEDs have had good reviews from Pelicanites.
Someone also linked this site Order Now Porsche
Rothaus can you provide a link for #3 and #4.
rothaus 03-25-2014 04:59 PM
The 2 set for testing are gone. Thanks for testing the LED's
I like to have some feedback before I offer them.
Engelbert
DaSurfa 03-25-2014 05:08 PM
Wow #4 looks great!
I have SB's on mine and while they are better than the stock, it's still inadequate.
Engelbert put me on the list when you get more.
Mahalo,
rothaus 03-27-2014 01:25 PM
The test set's are in the mail.
Cheers
Engelbert
poorsha 03-27-2014 01:47 PM
" Rothaus can you provide a link for #3 and #4."
" I like to have some feedback before I offer them."
Guess not.
RocketWrench 03-27-2014 02:31 PM
Are the origins of #4 going to be made public? I don't really care about the cost, I really need these LEDs....?
rothaus 03-27-2014 04:53 PM
Thanks for the response, I really wanted to see how others like them before I start selling them. However, if you don't want to wait, please PM me.
Engelbert
Michael T 03-27-2014 05:26 PM
I installed etarga's vintage LED's. They look great. The lower color temperature is closer to original and matches the HVAC panel's yellowish color. No fakey blue color. I
rothaus 03-29-2014 10:33 AM
Update:
Here are 2 pictures with the complete set installed.
Here with the white
http://airboxer.com/images/All_White_01.jpg
Now I have also the warm white or AKA Vintage Look. I switched all of them out with the white once. I personally like them both.
http://airboxer.com/images/All_Warm_White_01.jpg
Cheers
Engelbert
nineball 04-01-2014 11:39 AM
got mine in the mail today and the weather is cooperating. with any luck they will be installed tonight and pics shortly after.
rothaus 04-19-2014 03:03 PM
I got one last set of the white left. I got a few sets of the vintage white available.
Cheers
Engelbert
avale 04-19-2014 10:21 PM
Pm sent for the white set.
-Alan
GaryR 04-20-2014 06:35 AM
Englebert - PM sent for "Vintage"..
Jp-oh 04-20-2014 04:37 PM
Pmed as we'll.
Cheers
rothaus 04-20-2014 05:48 PM
Responded to all PM's SmileWavy
Engelbert
rattlsnak 04-20-2014 06:59 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/644374-ultimate-led-ba7s-bulbs-gauges-ala-etarga-pic-vid.html
rothaus 04-21-2014 05:27 AM
To save a step on PM's here the info about the cost.
They #4 LED's, with the LED on top and the 2 side LED's are $36 for the set (8 + one spare) includes also the spacer needed for the clock, and instruction, plus $4 s/h, total $40.
http://airboxer.com/images/LED_BA7s_New.jpg
Here is a video clip to demonstrate the dimming of the new LED in the picture above. Thanks to Kevin, who installed these in his 914.
<iframe width="560" height="315" src="//www.youtube.com/embed/kF3Uz8gjGWM?rel=0" frameborder="0" allowfullscreen></iframe>
Engelbert
GaryR 04-21-2014 05:33 AM
Englebert, can you get the turn signal indicators in green LED?
rothaus 04-21-2014 05:59 AM
I will get some green and blue for the parking light indicator in the speedo, and high beam in the tach. I tested them in my SC and they work great.
I have not tested yet how they would work for the turn signal indicator.
These color LED will have only one LED on top since the only need to shine straight.
As soon I got them I will post some results.
Engelbert
rothaus 04-23-2014 05:21 PM
I got again the bright white LED's.
I now have also Blue and Green LED for the High Beam indicator and Parking Light indicator. These LED's need only on large LED at the tip, see picture below. They can be added to the Set of the multiple LED lights for $3 each.
http://airboxer.com/images/LED_green_Blue.jpg
Cheers
Engelbert
KWIQSLVR 04-26-2014 10:00 PM
Just installed the white LED's and the difference is...night and day. (sorry, couldn't help it). They're really a huge improvement over the stock bulbs.
Rich Gas 04-27-2014 05:43 AM
These spam bots take a snipit from a post and try to make it look real...as you found out it redirects you to some bs site. You were lucky it wasn't something more sinister... Don't click on those... I'm going to want a set of your LEDs ...
glennanddenise 04-28-2014 05:14 PM
Pm'd as well.
tirwin 04-28-2014 07:36 PM
I installed one of Engelbert's LEDs in the clock tonight. Thought I would post a couple of pics to try to show the before/after difference. I'm very impressed!
From the passenger side:
http://forums.pelicanparts.com/uploa...1398738875.jpg
From the driver side:
http://forums.pelicanparts.com/uploa...1398738928.jpg
The instructions are very clear and easy to follow. An excellent upgrade!
rothaus 04-29-2014 03:56 PM
Looks good !
Thanks for the feedback, just wait when you got them all installed.
Cheers
Engelbert
tirwin 04-29-2014 04:28 PM
Hoping to get the rest installed tonight. My daughter looked at it and said it was a huge difference. "Wow, Dad... that one makes the others look so old!" :D
ma356r 04-29-2014 04:32 PM
ROTHAUS. any Vintage sets left? Would like to purchase.
Thanks.
rothaus 04-30-2014 02:31 PM
All PM's answered.
I have both white and vintage white left. As well the green and blue.
Engelbert
cwinters01 04-30-2014 04:59 PM
I recently ordered the whites and replaced my 5+ year old bulbs. I, like the others that have recently posted, am very happy with the outcome! Much brighter and I like the white look vs. the yellow...obviously a matter of preference here though.
Thanks again Engelbert,
Christian
dshepp806 04-30-2014 06:57 PM
Etarga has some good products,..for sure.
Best!
Doyle
M Bryan 05-01-2014 11:55 AM
67 green gauges
will these work in the green 67 gauges? is the number of bulbs the same? also what about the colored LEDS for these gauges. Thanks
rothaus 05-01-2014 05:47 PM
I don't see a reason why these LED's would work in the green gauges. I have not access to test them, however, as long they are BA7s, they should work. I think the number of the bulbs for illumination is the same like for the newer gauges.
Maybe somebody can confirm this.
Cheers
Engelbert
