no start 1987 carrera
Here is the issue my car was doing fine, till i put it in the garage for a broken odometer fix. It currently has no speedo. I went to try to move it and it won't start. Do 87 no run when the speedo is out?
Old 05-28-2014, 09:41 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Speedo should not affect starting. Check DME relay under the drivers seat first.
Old 05-28-2014, 09:49 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 No Odo should be fine, I drove without one when I had all my gauges refurbished but you did tape/insulate the connectors, right?
You may have drained your battery, make certain there is 12.6+ volts
+1, swap the spare DME relay as suggested.
'85 Carrera Targa
PCA/POC
Old 05-29-2014, 03:49 AM
Send a message via AIM to fintstone
What are the symptoms? Does it crank?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 05-29-2014, 06:33 AM
no start 87 carrera
Ok guys it started up again. After the first person here told me that it should run without the speedo,i searched for fuel pump syntoms and dme relay syntoms as well they all check out ok, then somebody was talking in a thread about those three connectors on the driver side intake manifold which are bolted on a metal plate. They said that the same problem arouse for them a no start condition and that the wires wer aking bad connection due to being fried from the engine heat after years. Well i go and king of replug these and bam it fired right up and still is doing fine. Guess i'll have to check those connections. What led to my symptoms as i backtracked my actions was that i replaced both front and rear lid struts but i was having trouble with that rear strut due to my huge hands and limited space so i must have disturbed those connections. Well the good thing is that is runs. Thanks to all thast replied and that got involved with this issue i was having. I like sites like these where seriouse proffesinal people get involved and help without any type of bs. Take care and thanks to all
Old 05-29-2014, 10:42 PM
