2.7 with new MSD 8524 and coil - missing badly
Over the weekend I completed the MSD upgrade from Wayne's article 24.
This was brought on by a no start issue and feedback from the forum was that this was a coil or CD box. In Wayne's article he suggests re-timing, which I have not done yet. I drove Sunday night and it ran pretty well. Since then, I have noticed less power at low RPMs with some slight misses and it got worse over the last couple of days. This morning on the five mile trip to work I had a stall at a stop light and backfire when pulling away. From those who have done these changes, is this typical? Do I need to change the distributor to a non-resistance version? I have not done anything to the plugs. They are about 2500 miles old. Also, the plug wires are not changed out. Any suggestions on where to start? Thanks. |
Recheck your connections. Coil primaries, etc.
Tell us in detail how and where you grounded the unit. This is really really important. Right now, the last thing I would suspect is the hardware and the first would be installation. Timing maybe, but for now, reach in there and see if you can twist the dist by hand. Maybe it's loose and you just bumped it? |
How are you triggering the MSD? Do you still have points (upgrade to pertronics would be great)? An msd box will stress old wires, caps, and rotors so make sure yours are up to the task.
points are fine. more reliable. i ran my 77 for 10 yrs and i think i changed the points once.
the gap is not critical, but do make sure they open and close completely. i would check it. the bushing can wear down and the points wont open. i do not know what the 8524 is. i looked it up and a distributor came up. did you replace coil too. i dont knos this unit so i dont know how it should be wired. does it have a dedicated wire that runs to the battery? were did you connect it? does it have a dedicated pair to the coil? is the coil still grounded? bob's questions on grounds. marks question on triggering. what about timing? advance working? plug wires OK? check for arcs and sparks at night with all the lights off and engine running. if you have a multimeter ohm them out. cap and rotor good? how do the plugs look? the wire form the dist to the CD came get brittle and crack and short out. outside of that it sounds like fuel or an air leak. |
After a tune up and wiring check i would check gas filter and fuel pump pressure.
My bad, it is a 6425 MSD unit
I got the model number wrong. Sorry for the mis-info.
The MSD is connected to the starter hot wire and the ground from the MSD is to the back of the aluminum panel. I could use some insights if someone thinks this should be a better ground. I am confident of the connections to the coil and used the plug from the factory perma tune for the white and red wires, so I am hopeful those are not the issue. I just drove it home and had a couple of misses, but nothing major. There is nothing like a little "bucking" at high speed to create a loss of confidence. I am still new to this and appreciate the insights and advice. |
You can run into problems like you describe if you try to use parts of the factory wiring harness. It is best, if not mandatory to use the MSD harness by itself. Read their install instructions and use the proper spark plug wires, and resistor plugs.
The current way it is running sounds erratic, which is most likely EMI interference. |
The ground could be better if connected directly to the chassis. Also clean the coil connections. Maybe open up the gaps on the plugs a bit.
Check for vacuum leaks, also check for any plugs or hoses that may have came loose when you were installing the MSD. |
Do not discount the importance of the ground. Remove it from the list of possible causes. Grounded to the panel, it's suspect. |
Thanks for the direction
OK, I will start with an improved ground connection and double check the hose connections. The coil is new and the connections are clean.
I'll post more as I sleuth this one. |
Magnetic pickup is much more reliable and accurate. Points major shortcoming is unavoidable rubbing block wear. As a minimum, if you haven't done so already, NEW points, then time. Plus the condenser will have a much greater spark delay with CDI vs with a ~1 ohm ignition coil primary. |
As mentioned make sure you have a very good ground.
ALSO make sure you have a very good power lead. I had trouble with my Daytona-Sensors CD-1 install because I connected the power line to the big red wire that goes to the starter, but I connected it AFTER the 14 pin connector. It backfired and quit running a few times. I cleaned the connector and all was well. Later I connected the new power wired downstream of the connector and installed a 20 amp fuse in the line. Everything was fine then. Point here is the MSD puts out at least 2X what the bosch did so you need to be sure that the wiring is right. If the above does not do it, look at the points and timing. |
as a follow up make sure the signal going into the MSD is good. If your point gap is too small the running can get erratic and sometime just quit when the rubbing block wears away and the gap get minor on non-existant......I have learned this over many times. That was the major reason I switched to Hall effect Pertronix.
I have an MSD tester that I bought on eBay that simulates the points output. You can dial up different RPMs. I use it with a spark testing gap. this video explains it well. How to test for spark on your MSD 6 Series - YouTube Maybe someone has one near you. I wish I were closer to Walnut Creek, I would be happy to help you out, and test the MSD and the spark input and wiring. I have spent a lot of time getting to know the early 911 ignition system and upgrading it. I have a 2.7 MFI motor that I have running great. I have acquired some good test equipment. At least you will know the MSD is working well. Just too bad you are not closer. here is the plug tool that you can hook to the coil output http://forums.pelicanparts.com/uploa...1396624416.jpg |
So, it seems normal the last couple of days
I have not had time to address this issue over the last couple of days, but plan on looking through connections first thing in the morning - starting with the ground.
I appreciate all of the insights. Jeff |
LQQK, the CDI is quite obviously firing the spark plugs!
Put in NEW points and condenser, set 70% dwell..... Check the TIMING. Then fiddle-futz around with the wiring and connections. |
+ 1, I am a fiddle-futz pro.....this stratagey allways works for me, its allways the last thing you check so just go there first!
check the rotor. msd will burn out the resistor rotors. it's pretty obvious when it's toast. use an echlin with no resistor.
JW comes up with stuff that lots of us don't know enough about. Check your rotor. The ground may or may not be problematic. Nail it and put it to bed. Check your points, check your timing. Buy tools if needed. |
Whether or not it could happen. |
do you have a video of the misfire?
But sometimes it looks normal even after the resistor burns. |
Also if you get the green and purple wires from the MSD mixed up it will run, but run rough, check to make sure the green and purple wires are correct.
Somebody mentioned points above, I don't think you have points do you? The Green and purple wires run to the distributor pigtail, it's a funky shielded coaxial concoction, but try reversing the green and purple wires and see if it works better? |
If you have points or pertronix it is a white wire for point trigger. If you have a magnetic pickup it will be green and purple.
The polarity on the magnetic sensor can be reverse, but I have no personal experience with that. I would check the signal from the points / magnetic....whatever you have into the MSD. This is best done with a scope although you could use a volt meter. |
"Point here is the MSD puts out at least 2X what the bosch did so you need to be sure that the wiring is right."
And that's a real problem! The complete ignition system, i.e. the rotor, cap, ignition wires, cap wire connectors, and the spark plug connectors all get over-stressed whether initially or long term. There's really little to no benefit in over-stressing the ignition system beyond what's necessary in ignition energy and voltage. |
Hmmmm....... 95% dwell or open condenser? 1.) Ran pretty well....2.) slight misses....3.) Backfire..... Kettering ignition system (coil/points/condenser) w/open condenser or 95% dwell (rubbing block worn down) would result in the low coil primary voltage arcing across points as soon as they open ever so slightly, no coil secondary plug firing = NO START. CDI w/open condenser .... No point BOUNCE filter....Plugs fire EARLY as points open AND possibly again as they close. While a properly functioning condenser would have little affect on the plug fire timing with the Kettering ~1-3 ohm system, CDI designers would expect it to substantially delay the plug firing timing and therefore REQUIRE re-timing. CDI w/95% dwell......LATE plug firing, rotor nearing mid-point between two distributor spark plug "contacts" = Carbon tracking on distributor surface forming over time, miles driven. CDI w/95% dwell = late plug firing "post" TDC = engine overheats = BACKFIRE! Or.... Original point dwell was >95% due to rubbing block wear, thereby firing the coil primary, spark jumps across the points = no start. Initial CDI timing would have been after TDC, but as rubbing block wears more and more CDI begins firing only intermittently. Someone installed new points but didn't properly lub the rubbing block? Forget the lub, rubbing block seriously wears down within 800-1000 miless (69 Ford V8, Seattle/Lewistown, MT) |
Working from home...
OK, the saga continues.
I have been running it and there were a number of trips where it felt "normal" On Sunday I moved the ground from the MSD to the bolt on the inside fender as was suggested. I took it out for a spin and got up to highway speeds with no issues. Last night I stopped for fuel, topped off the brake fluid and then ran it home. The temperature gauge went up, just shy of 210, all on a trip less than four miles. There was a lot of heat on the back right fender and heat coming out from behind the tire. I have seen references to overheat and the backfires so can I assume that these are related? This morning, it started to miss about 3/4 of a mile from home and then at about the 1 1/2 mile mark I got some serious backfires. I pulled into the left turn lane and it stalled. I did get it started and made it back home. I kept it at high RPMs so it wouldn't stall. I had a few more backfires, but the half mile up my street was smooth and quiet. From the MSD wiring harness there is a lot of extra white and red wire. I rolled it up and positioned it in the back left of the engine compartment. Is there a chance that I am getting EMI from the wires and this is causing these intermittent issues? What is suggested to do with that wire? Do I need additional shielding? What seems most logical at this point is to go down the path of John Walker and look into an echlin rotor. As always, the advice and insights are helpful. |
i've had perfectly new distributor caps cause a cross-fire even without MSD. rare though. i'm not a big fan of MSD. sometimes the multiple spark doesn't go to single spark above 3K like it's supposed to, resulting in a lot of backfiring. the bosch system works just fine. ever get a shock from MSD?
I am picking up a new rotor and cap this morning.
No I haven't gotten a shock from an MSD - that sounds, well shocking. Do you think EMI is an issue with the extra wire? If so, what do you recommend for shielding? |
craig had problems with a new set of ignition wires.
i never had one on my 2.7. |
If the 2.7 used CDI that would be fine, with Kettering a condenser is REQUIRED.
If the 2.7 was shipped with CDI there very likely is a good sized, high capacity, condenser inside the CDI on the incoming point "signal". If there is no condenser then I would suggest adding one to filter out contact point bounce. The MSD design may have been expectant of a condenser. |
as the rpms get up there, 3K and above , there's not enough time for multiple sparks.
If the MSD significantly improved spark energy over the older setup you could have something as simple as arcing from one or more spark cables to some ground point.
Did you try looking into the engine bay very late at night in pitch black conditions? Your looking to see if any arcing is visible anywhere along the ignition cables or near the coil it self. |
Start with a resistor plug wire set like Clewett, resistor plugs and a separate harness for the MSD, only as long as needed.....not tied in with the factory harness. If your wire harness is coiled up from being too long, this can induce EMI problems from what I have experienced in the dyno room. If any of the MSD harness crosses ignition wires, try to do it at a 90 degree angle. |
So, just as long as that "second" firing occurs within 2-3 milliseconds, before the rotor is closer to the "next" plug connection than the plug just previously fired, no harm, no foul... Plus, even were the second firing later than 3-4 milliseconds there is more chance for pre-ignition, not backfiring |
Sure glad we now have COP ignitions....
We'll see
OK, here's the rundown from last night. I stopped by the local Napa for the eichlin rotor and a new distributor cap. I thought this would be a pretty easy install and was looking forward to getting out on the road.
The rotor and cap were easy enough. The old rotor had a resistor and from what I read on the forum knew that with the MSD I didn't need that one anymore. The rotor was a little tight getting out, but it worked. I dropped the new one in and replaced all of the wires. I then went after the wiring that I had coiled up and tucked away from the original MSD install. When I took the plastic cover off of the wiring panel I noticed that one of the MSD rubber mounts had broken. This would cause the MSD box to vibrate while driving. I did not know if this could have caused an issue, but it did require me to pull the aluminum panel and redo the mounting. That took about an hour, part of the problem is that the nuts that MSD sent with the mounts are a smidge too small and getting those undone while gripping the base of the old rubber mount was a pain. Once done, I uncoiled the wires and laid them out towards the shock mount on the deep part of the engine compartment. Feeling pretty good about this, I hooked up the battery, wrapped up my tools and went to fire it up. All crank and no fire. Damn! I went to the back and found staring right back at me was the orange wire from the coil - without its connector on. OK, unhook the battery (can't be too safe) and I redid both the positive and negative connectors with extras from the MSD bag of goodies that came with the CD box. Hooked up the battery again. Went to turn it over - all crank and no fire. This time, I had my son turn the key and noticed that the MSD box was lighting up and I felt good about the connections there. I double checked the spark plug cables and the wire from the coil to distributor - Aha, this had to be the one - right? OK, this time it did fire and it was a nice smooth idle. It was getting dark and dinner was ready so I needed to clean up and call it a night. Had their been misses I would have shot video in the dark for any arcing, but that was not the case. I am headed to work and will add photos and provide an update in a bit. |
Got it on the road and pics
I fired it up and it idled weakly and died a couple of times. I was able to restart it with no problem. I backed out of the garage and it was still idling - about 600 - and had one small back fire.
I have about a quarter mile down the street before my first stop sign and that was smooth and the idle held at about 900 - 950. The rest of the drive (a couple of miles on city streets and a couple of miles on the freeway) was uneventful. At the onramp and offramp the idle was steady at 950. No misses and no backfires. I feel pretty good about where this is, but will keep an eye on things over the next few days. Here is a shot of the new cap and old cap and rotor: http://forums.pelicanparts.com/uploa...1397061493.jpg Here is the old rotor. It was a little tough to tug out of there, but ended up coming straight out: http://forums.pelicanparts.com/uploa...1397061512.jpg Here is that mess of wires from the MSD intstall before I undid the coils: http://forums.pelicanparts.com/uploa...1397061530.jpg |
