Brake Job Newbie
New owner of an 88 911 Targa. Emergency brake didn't work so I began the path to repair. Find out I have a cracked rotor disc so I am redoing the hand brakes, rotors and pads. I have begun reassembly and just spent an almost two hours trying to get those conical springs locked on the pins holding the brake shoes. This forum is outstanding so I know someone will have a suggestion on how to get these attached. Thanks for your help.
1988 911 Targa
1955 MG TF 1500
1974 Triumph TR6
Old 04-03-2014, 03:37 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Use a needle nose, hold the end of the lock pin and use other hand to push the spring back and twist the pin and to go over the divet to release the lock. Gosh did that make any sense? :-(
'85 Carrera Targa
PCA/POC
Old 04-03-2014, 03:53 PM
Probably not.......
Jim,
I did the rear brakes of my '73 VW Beetle 3 weeks ago and I could relate to your post. Have I not done it recently, I won't have any idea how to implement your suggestion. That's why pictures help a lot in explaining things the easy way.
Tony
Old 04-03-2014, 04:56 PM
Draco, I think your instructions make sense if I was unlocking the springs - already did that. Trying to put the new springs on. I think your idea about holding the pin in the back with needle nose may work as well. Thanks
1988 911 Targa
1955 MG TF 1500
1974 Triumph TR6
slimlynn1's Avatar
Did this last night, what a pain in the a$$!! I loosened the cable all the way, a helper would be key!!
Old 04-03-2014, 05:22 PM
non-whiner
mreid's Avatar
A brake tool makes it easy. That cylinder on the upper right allows are to slip them right into place:
"Too much is just enough."
Old 04-03-2014, 05:26 PM
I'm going to be doing this within the next week. Link to tool?
Old 04-03-2014, 05:59 PM
