flash951's Avatar
Broke of piece of metal, how to fix?
A piece of metal was broken off when I tried to loosen the bolt for the oil pressure sender. How can I fix this? Ideas?
Remi Jakobsen
911T DP targa -71 (2.7L)
Phone: +47 92844671 (Norway)
Old 12-29-2010, 10:37 AM
Burn the fire.
Brando's Avatar
Uh oh...
I don't think JB weld is going to do the trick.
What's on your "While I'm In There" list for a teardown?
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 12-29-2010, 10:45 AM
cattman's Avatar
Give JB Weld a try. For cold weld, nothing is better.
CATMAN
2005 Porsche 911: 997S, supercharged to 530HP
1987 Porsche 911: Concours prep OEM guards red on black
Friend of Warren
Oh that is not good. That is part of the engine case. Late model cases are aluminum, but yours might be magnesium. If aluminum you could pull the engine and have that welded up and re-tapped. Don't know what you do if it is magnesium. Hopefully someone on the board will have an idea.
Kurt V
Old 12-29-2010, 10:47 AM
Somewhere in the Midwest
MotoSook's Avatar
If I'm not mistaken, that is part of the case, and it won't be an easy fix. It'll take some custom work to fix it, like a threaded in piece that is epoxied as well, then a new hole drilled and tapped (a little further out than original) to accept the oil pressure sender block and cam oil line.
Old 12-29-2010, 10:48 AM
Wilywilly's Avatar
Put some duct tape on it.
Bill B.
63 Little B Coupe
67 SWB 3.63 Hotrod
08 Cayenne S
65 F100
Old 12-29-2010, 10:50 AM
HarryD's Avatar
Assuming that this is the 1971 engine, it is magnesium.
This is a pressurized location that will need to be strong (design pressure can be 100+ psi). If you can find a shop that is competent in welding Magnesium alloy, you MAY be able to get it fixed. Do you have the piece that broke off?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-29-2010, 11:07 AM
Wood Magician
Old 12-29-2010, 11:14 AM
flash951's Avatar
I have the piece that fell off.
Remi Jakobsen
Old 12-29-2010, 11:17 AM
Senior Advisor
James Brown's Avatar
Looking at it it's almost 1/2 the diameter of the fitting. Any repair that doesn't involve replacing the case half will not work. You can try to epoxy it, cold weld, put a rock in it, whatever sooner or later, with oil pressure pushing against it, it will fail. Sorry but this is a major breakage. And if it's a MAG. case, good luck finding a welder to repair this.
08 Cayenne Turbo
Old 12-29-2010, 11:24 AM
yer screwed unfortunately. take heed, those who advocate removing the sender the "easy" way. take the block off and clamp it in a vise, then reef on the sender. you will need a new engine case. the small amount of metal there and the close proximity to the oil passage make for a very shakey repair at best.
JB weld? are you kidding?
206 637 4071
Old 12-29-2010, 12:06 PM
That area goes up to 80psi... I can't even imagine the legal liability as you spew 10 liters of oil all over the road within 30 seconds or so...
I feel for you, but that needs to be welded. If you are lucky, someone might be willing to try to TIG weld that in situ and tap it...but if any shrapnel gets in your motor you are toast...
Old 12-29-2010, 12:29 PM
As a temporary fix, without pulling the motor and tearing it down, you might try to plug the broken area and utilize the nearby temp sender bore to feed the cam tower. You'll have to get creative, use a hollow bolt and fabricate a block to tee into. My example, below, is probably too long, but an MFI filter console bolt should work...
Jon B.
Vista, CA
Old 12-29-2010, 12:36 PM
Mike80911's Avatar
I cracked the tab off for the AC compressor on the block of my 928 once took it to the best welder in town he built the area up by welding it over and over and then tapped it out worked great and did not even have to remove the engine. I know mine was aluminum but I would guess the right welder could do the same for you Good Luck
Old 12-29-2010, 12:43 PM
RETIRED
Joe Bob's Avatar
Just thinking out loud.....Can't you pull the sender, weld it closed?
Deal with oil pressure somewhere else?
2012 ML350 3.0 Turbo Diesel
Old 12-29-2010, 12:47 PM
Are you guys sure that some JB Weld won't do the trick? At least for a temporary fix?
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 12-29-2010, 12:58 PM
there looks to be about one thread left. i don't think plugging it is going to work.
206 637 4071
Old 12-29-2010, 01:00 PM
John, you might be correct, but plugging the broken area would be far easier and safer than a fix to support the pieces hanging off it, and the bolt to fasten them, with engine still in car. Someone in Norway would have to examine the situation and decide, but his only viable alternative is very, very expensive.
Jon B.
Vista, CA
Old 12-29-2010, 01:42 PM
AutoBahned
RWebb's Avatar
well, the question is how temporary and when it does fail it will be catastrophic - not just a big oil spew but a destroyed motor
sad to say - the BRIGHT side is that you now have an excuse to build that hot rod you've always dreamed of
Old 12-29-2010, 01:47 PM
Wavey's Avatar
God, this thread makes me sick. I feel for you, Remi!
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 12-29-2010, 02:12 PM
