Finhead
3.2 Surging/Bucking :( Fuel tank filter?
Greetings all.
I have a 1986 3.2 that was running fine until yesterday. It was running great until I stopped at a stop sign on a somewhat steep street. The car had about an 1/8 of a tank (or maybe even a bit less) in it at the time. As I pulled away from the stop sign it began to surge and buck (hasn't done that before) and has continued to do it since then. Thinking that I may have starved the fuel pump due to the steep incline, I went straight to the gas station and filled the car up. The issue has continued and is getting worse. The car was idling fine but would surge and buck off of idle. After surging and bucking, the car would die. It would then restart and idle fine but again would surge and buck off of idle. The fuel pump can't be heard when starting the car but can be while it is running or immediately after the car dies. Any suggestions? I've read through the different threads regarding surging and bucking and all of the potential causes. It may just be coincidence, but given when the issues started, I'm wondering if the fuel system could have picked up some trash. Perhaps the fuel tank filter? Anyone encounter a similar issue in the past? Thanks! 2cam |
Member 911 Anonymous
You do have a back DME relay, right? first try that.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
If you suspect fuel starvation DO NOT apply any heavy load on that engine till you resolve the issue. These motors do not like running lean and can be permanently destroyed from lean mixture resulting in detonation.
You should do fuel pressure test and fuel pump delivery rate testing.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Do you often run it low or was this a rare occurance?
Finhead
I don't have a back-up relay (just recently purchased the car) but will pick one up. Thanks for the suggestion. Although I was leaning more toward a fuel issue due to the circumstances that immediately proceeded the surging (low fuel/steeply inclined street).
First time, but to be honest, I've only had the car about a month. Could a blocked tank filter impact the fuel flow significantly enough to cause the surging and bucking? Thanks! 2cam |
These cars are old and who knows what's in these tanks. So I'd say it's very possible something from the tank could have caused some sort of blockage. Fuel Pressure test and fuel delivery rate test may help point you in the right direction.
It could, and when you run it low you increase the chance of picking up things from the bottom that have accumulated over the last few decades.
Since fuel pumps tend to fail all at once in my expierence, I would suspect you are ok there. That said, they cool themselves via gas so running out of fuel is very wearing on them. |
muck-raker
the fuel filter in the engine compartment can give you the same symptoms. What do you know about its history?
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Immature Member
Try this thread
My problem was exactly like yours. Idled fine, but bucked and hesitated at throttle tip in. Smoothed out and drove normally after I got past 2000rpm or so. Sound familiar?
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
On a low tank an a steep incline my money would be on dirt in the fuel line. IŽd certainly change out the fuel filter. I had slight bucking myself after getting dirty fuel. Drained the tank and changed the filter and it seemed to do the job.
Finhead
Thanks to everyone for their input. 2cam |
Diss Member
Test the fuel pressure while running.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
