DougZ's Avatar
Shift Coupler Tight
Last night I installed new bushings from Pelican on my 83 SC shift coupler. Disassembly and installation went well except when I drove the pivot pin back in place the pivoting of the spline shaft is very tight now (up/down motion). Is this normal? According to video from ED this movement should not be tight. Is Pelican bushing ID always tight like this when new? I don't think I damaged anything on the pivot pin. Ends are not mushroomed as I can tell. I did assemble it to the car and it seems like it works OK. I didn't have a chance to drive it yet. I just want to make sure it's OK being that tight. Do you have to grease anything?
"There is no old Porsche, just a new Porsche owner"
Old 04-03-2014, 08:32 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Under normal circumstances...Delrin (bushing) does not require lube.
It won't hurt to put a little Lithium grease (or similar) on the Delrin before assembly.
Bob
Bob Hutson
Old 04-03-2014, 11:28 AM
Jp-oh's Avatar
I had the same issue. Mine was more snug after the new bushings but seemed very smooth and shifted well when all installed and adjusted.
1986 Meteor Grey Carrera - We'll meet again in Valhalla.
Old 04-03-2014, 11:43 AM
DougZ's Avatar
Sounds like it will be OK. I'll give it a shot and use it.
Thank you for responses!
Old 04-03-2014, 12:47 PM
