Bright Switch-Steering Wheel Remover
I have developed the infamous 'hit a bump and the headlamps turn onto bright'. So, while researching how to fix it, it looks like I'll need to remove the steering wheel.
If I'm removing the steering wheel, it seems like a good time to put a new one on since mine is cracked in 4 places and crooked.
The last time I removed a steering wheel, I was sixteen years old and nearly chopped my own head off.
Can anyone recommend a good steering wheel remover? Hopefully, on Pelican. My searches come up with nothing.
As an aside, is the Momo the best option for an 86 3.2 Carrera?
Old 04-04-2014, 09:04 PM
I have never used a puller on my 911. It just comes right off.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 04-04-2014, 09:08 PM
Member 911 Anonymous
DRACO A5OG's Avatar
No special tool needed, just use a deep socket and remove. Take care not to over torque it on install, it can mushroom the spindle then it will be a biotch to remove the next time.
Just make sure you remove the fuse or disconnect the battery.
Center the wheel and try your best not to move the wheel side to side before removing or score/mark the spindle prior to removal.
Jim
P.S. searchh WON headlight switch, WON started it and many contributed on the switch repair.
'85 Carrera Targa
PCA/POC
Old 04-04-2014, 09:09 PM
Socket?
Jim
Thanks for the tip! Do you happen to know what size socket it takes?
Old 04-04-2014, 09:14 PM
pors1968's Avatar
I think is 28mm
Old 04-04-2014, 09:36 PM
7.0:1 > 11.3:1 > 7.0:1
Back the nut off a couple turns then unseat the wheel - safer.
Old 04-04-2014, 09:41 PM
DRACO A5OG's Avatar
That would be it.
Also do not use the steering wheel lock to hold it in place while you loosen or torque the nut down, you do not want to break it. Have a helper hold the wheel while you loosen or hold it tight with one hand.
'85 Carrera Targa
PCA/POC
Old 04-04-2014, 09:42 PM
Porsche steering wheels are not fitted with a taper, and come right off. There are NO 28mm wrench size fasteners used on a Porsche, IIRC. The nut is 27mm. Mark the wheel and shaft with a scratch to help get it back on right. Tighten the nut by holding the steering wheel in one hand and the ratchet or breaker bar in the other. Real tight is good enough. mind you don't slip and break the windshield!
The Cap'n
Old 04-04-2014, 09:47 PM
Vintage Owner
Jack Stands's Avatar
Deep 27 mm deep socket with a short extension is what you need. Just loosen the nut a few turns, give the wheel a good pull, and it will come loose. Then remove the nut and remove the wheel.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 04-05-2014, 06:33 AM
pors1968's Avatar
I guess my memories is fading 27mm is the right one.
Old 04-05-2014, 07:15 AM
Barrpete's Avatar
I use one of those "Club" steering wheel locks to hold the wheel for leverage while turning the nut.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 04-05-2014, 07:58 AM
