2002 996 C4S
jcsjcs's Avatar
Question Removing A Arms (Control Arms)
Hey All -
Trying to remove my A Arms from the car. I have everything disconnected - but am having trouble pulling them out of the bushing that is next to the rear of the torsion bar.
Should I remove the torsion bar first? Any other tips?
There are A LOT of threads where people are removing their bushings and the A Arms are already out of the car - but I can't quite get to that point.
Thanks - Jonathan
jcsjcs
Have: '02 996 C4S
Had: '87 944, '84 911 Carrera Targa
Old 05-05-2014, 11:02 AM
abit off center
cgarr's Avatar
Pull the t bars and remove a arm with bushings attached you will not be able to put it out if the bushings.
______________________
Craig
G2Performance
Old 05-05-2014, 11:08 AM
2002 996 C4S
jcsjcs's Avatar
Yup- just discovered that. For some reason, we thought the A Arm had to be pulled differently.
Removed the long bolt and pried out the A Arm.
Now to heat up those Bushings and get them out.
Rebel Racing going in!
jcsjcs
Have: '02 996 C4S
Old 05-05-2014, 11:12 AM
