Yes that is Pasha cloth
sparco 368 wheel?
Like so many, my leather stock three spoke wheel has deteriorated at the top. Looking into replacements, I found this old thread.
Steering Wheel Diameter Size Looking at the prototipo style wheels I noted that they were all only 350mm, smaller than the stock 380mm wheels. I already have enough trouble horsing the 205/17 tires in and out of a Chicago box at the autox and so didn't want to go down any in size. Also at 6'3" I find the wheel just a bit too far away to reach comfortably when the seat is far enough back for my legs. I do crank the seat back upright more, but then I run out of headroom quickly. But then I stumbled upon this wheel SPARCO 368 COMPETITION STEERING WHEEL Seems like a great possibility. Same dia, lots of dish to move the wheel closer. With the dia and dish I think that the visibility would be the same or better than the stock wheel, and there might be a bit more leg room under the wheel as well. So what do you think, has anyone tried this wheel?
84 RoW, slicktop coupe, with Pascha baby! 08 GTS Cayenne |
Go-Kart Mozart
It was at the top of my list until I found the Abarth wheel. The Abarth is 370mm with a little dish, but has a more period look. I know Arne here has one as well. We've both posted pics if you search. Can't say much about the Sparco other than like you I thought it's size and dish filled a gap most steering wheel makers skip over. -J
ETA: I'm using the Zuffenhaus hub and JWest eccentric to get the wheel up and closer to me.
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken Last edited by JAR0023; 04-05-2014 at 10:27 PM.. |
I have the exact same wheel in one of the smaller diameters ( I bought it used). I am 6'4". I have racing seats and custom welded mounts to lower the seats. I even added a 1/2" spacer that offsets the wheel up a little, it gets the wheel closer, up off my legs and vastly improves gauge visibility. Hopefully some of my rambling helps. If I was buying new I would try the 380mm wheel, seems like a great option.
The only negative about the wheel for me is aesthetics, it does not fit the look of our 911s interiors as well as the Prototipo. I think Sparco makes a wheel with holes in the spokes similar to the Prototipo? do they offer it in 380mm? One other note - I have had 2 suede wheels now and the suede does not look nice for long. If I was buying new I might go with the plain leather. I think it might hold up better.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Thanks for the input guys. I do like the look of the Abarth wheel. Can't find a new one in a quick search but the Momo Retro is the look without the dish though. Good point about the suede going bad quickly. Did you see that Sparco sells a suede brush? Brass on one side and rubber on the other.
So with the sparco do you think I would need the JW eccentric adapter? Does that have a function other than making the gauges a little more visible? I have time to look for just the right one, it's not top priority just yet.
I dont think you need the adapter with the larger wheel - I think you will be able to see the gauges. it also brings it back a 1/2" but I think you can get a non eccentric for that.
Have to look into one of the suede brushes.
Go-Kart Mozart
I bought my Abarth via Ebay from Mr. Fiat. ETA: I just read the description and it's now listed as a 350mm wheel. They are in Atlanta so easy enough to call and find out. -J
http://mrfiat.com/index.php/fiat-500-600-abarth-steering-wheel-3-spoke-new.html
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken Last edited by JAR0023; 04-06-2014 at 05:10 PM.. |
abides.
I have the Sparco 345, which is what it sounds like Erik has also.
I'll +1 him on pretty much everything. Skip the suede, add a spacer or two. As long as you're not a purist who scoffs at the thought of having the Sparco name in your car, go for it.
Graham 1984 Carrera Targa |
