Cure for front inside lifting is more rear roll stiffness (ARB or ride springs)
Cure for jacking other than redesigning the suspension (or lowering the car to lower the roll center and CG) is to increase the ride spring rates so that the car jacks less for a given lateral load. I don't think it is a jacking issue. The magnitude of the jacking force on the outside tire should only be about 50-100 pounds which will only extend the suspension about 3/4". |
Flieger,
I had a local expert who was running a very fast 912 (on apparently stock sized rubber!) at the same autocross strongly reccomend stiffer rears - he was running 26mm, and he recommended 25mm for may car. I went with the 26's because they were available and I was impressed with the way the lighter 912 handled on the track. My car is a bit heavier in back, so I assume my ride will be less compromised than his. They strongy recommended new shocks - and recommended setting them to the softest setting. He was running Ohlins shocks, I dont' have that kind of money. I have already ordered a fresh set of Koni classics to replace the factory installed Koni's that are on the car now. Finally, he said I could pretty fearlessly drop the car 30mm. I may go a bit farther, but I'll use 30mm as a starting point. 912 guy was not a big fan of rear sway bars because he said it had a strong adverse effect on ride quality - recommended higher rate torsion bars instead. All these things together would get my car pretty close to his 912, which was completely stock up front. That 912 did amazing things on stock sized rubber (he was running Avon tires) but it still retained it's stock look and was a comfortable driver. |
As stated earlier, ride heigth is Euro stock, but I think it's going to have to come down. I'll start with 30mm and probably keep dropping until it gets annoying as a daily driver. The higher spring rate rear torsions are already in my possession. I'll be installing them sometime in the next few weeks. - probably the same time as the new shocks. |
26mm in the rear and you will have a sweet auto-x car with the right amount of oversteer available on the throttle. Get it to what you call "euro height" and dial in as much negative camber as you can get in the front and add 0.5-1 degree more in the rear. Slight toe-in both front and rear, maybe a bit toe-out in the front to get quick turn in, but I think I would start with toe-in first. I have a good friend with that setup (+ stock rear swaybar) and the car, a 73S, is quick and fun. |
Please allow me to briefly explain myself. My car is 45 years old - and was not in my control for about 35 of those years. There are some components, like shock absorbers, that are of unknown age, but very well may be original to the car. Judging by the extreme deterioration of the rear shocks I removed I think there is a very good chance that they were equipped at the factory. Things like shocks wear - and in my case are likely worn. When I bought new ones, I didn't go for some fancy racer's special, I got the OEM stuff - which was originally adjustable when out of the car. I'm also starting at a significant disadvantage: my car was factory equipped with the "comfort group" which does make the car ride well, but handle awfully. I will admit to having furthered the comfort philosophy by insisting that all suspension settings be stock. At this autocross there was an expert driving a '68 912 with very heavy patina - it was brilliant on the track. I'm following his suggestions to get my car to the same point using secondhand stock Porsche parts and OEM replacements, and a lot of elbow grease. As long as it's a daily driver, it probably won't be a savage autocross beast, but I've seen how brilliant these old chassis can be when properly tuned, and how much drifty fun can be had. I'm looking forward to getting it set up a bit more competitivley. :) -Dan |
A couple of observations. Obviously suspension design and modifications are a complex issue.
1. Forget 912s. Different animal. There are two here in Nor Cal that will tear up an autocross. (very annoying) 2. Sway bars. They serve two functions. To limit roll of the body AND to balance the roll stiffness of each end of the car. Meaning, if you just add a rear roll bar to your car (I am assuming that it never had one in the first place and it was not just removed by a PO) you will add roll stiffness to the rear. Problem is now you may have a car that wants to have the rear end slide out. Solution, increase the size of the front bar when you add a rear bar. (you should research stock sway bar sizes, there were several options) Keep in mind that going to larger rear torsions will add roll stiffness as well. 3. Shocks. Since you have Konis on order, set them soft and install them. If the car feels mushy, you can always stiffen them up. There are some advantages to Bilstiens, but, for them to work best they need to be custom valved to the weight and suspension of the car. 4. Ride quality. Any time you make an "upgrade" to your suspension, you probably will make the ride less smooth. However, if you do your homework and don't go overboard, you can firm up the ride without being overly harsh. (a friend of mine has externally adjustable shocks and stiffens them up at the track). If you stay with rubber suspension bushings and don't go too large on sways, you should be OK with ride quality. Questions. What size front sway do you have now? Is there evidence of a rear sway ever on the car? |
There are mounts for a rear sway bar, but no indication that one was ever installed. This seems consistent with a factory '69T speced with the comfort group. Intresting aside- I've read that the self leveling suspension was standard issue on all comfort group cars, but this one really looks like the Konis were on it from the beginning. I'm guessing you could custom order and delete the fancy suspension if you wanted to. -Dan |
(Although Koni's idea of red will always look orange to me) |
