NC Porsche Targa
Targa top fitting
Does anyone have a pic to show me how the front beading should sit in the front. Should I even be able to see the beading standing in front of the car? Have had the top redone and the correct seal is in, it still sits up higher than it looks like it should and wind noise above 60 is insane.
Thanks!
1989 3.2L Targa 1998 2.5L Boxster (on it's way to become a spec racer) |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Targa top.
![]() ![]() ^^^^^ Replacing these parts on our '86 reduced the wind noise down to the very minimum, and improved the fit considerably. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 04-15-2014 at 09:57 AM.. |
When you say correct seal, did you know that the replacement seal is not the same size as the original and it causes the top to sit too high relative to the windshield frame. The end result is a lot of wind noise. I'll take a picture of my seal height and the top installed and post it tonight. Edit. The pictures that 86 ssinit posted make mine redundant, gee I wish my top looked that good! I will also look up the email address for Dan in New Jersey, his shop can supply the right sized seal.
Dave Last edited by brighton911; 04-16-2014 at 03:33 PM.. |
The beading in the front and rear of the top should fit flush against the body, not down in the channel, nor up.
No, you should not see the beading while standing at the front of a Targa. Here are a few pics of a correctly restored top. This is from a 964 Targa that is very quiet compared to other Targa's I have driven and owned. ![]() ![]() ![]()
2021 Spyder 2019 Carrera T 2007 911 GT3 1973 911E RGruppe #295 |
Senior Member
You should not drive the car with a top that catches that kind of wind. The top, despite the safety catches integrated into the latches, can fly off and you will be weeping.
Clearly something is preventing the top from dropping into its position. The bead should sit exactly as shown.
'78 Targa in Minerva Blue |
The holes that the locating peg (item 9 in the post above) fit into can become plugged over time as the plastic deteriorates and ages on the pegs. Same is true for the rear (item 35).
If these holes are plugged up or have debris in the bottom it will prevent a flush fit
NC Porsche Targa
Thanks for replies. that top is absolutely gorgeous. I do have the correct seal from Dan, will try some remedies he gave me and check back.
Yes, both my targas have tops that look like that as well. Something is not right with your top. Side seals and window adjustment have an effect too. Roll down your windows and see if it seats better.
Targa Top Service Bulletin
If needed, I have a PDF copy of the Porsche Targa Roof Service bulletin.
Assuming that all of the seals are in good condition, along with the coverings & pegs: I adjust the windows on our Targa by: 1. Rolling up the window, noting any top lift. 2. Placing a piece of masking or painter's tape along the top of the glass. 3. Lower the window & check for even spacing from the top of the tape, to the top of the glass. 4. Window adjustment is covered in the Bentley. pm me as needed. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 04-16-2014 at 10:16 AM.. |
ok heres mine I got it from Dan last year. It is not the orignal.
![]() ![]() It looks great but I still get alot of air when driving. Just thought all targas got air noise. This a pic of the seal i think its orignal. Anyone know for sure ![]() As for flying off I have had it at 120 with no problems just the air noise ya get used to it.
1986 Porsche 911 Targa 1983 911 sc 2015 WRX |
Chris '75 911s Targa |
I do this for a living and have to say that Dave Brown is a targa god. I send the really badly tweaked tops to him and they come back perfect.
![]() Use this - Frost King E/O 3/8 in. x 17 ft. White Ribbed EPDM Cellular Rubber Weather-Seal Tape (Amazing Fit in Front Windshield) http://www.homedepot.com/p/Frost-King-E-O-3-8-in-x-17-ft-White-Ribbed-EPDM-Cellular-Rubber-Weather-Seal-Tape-V23WA/100145681 $4.98. No black version-but dark grey Walt Last edited by wjfk32; 04-16-2014 at 08:07 AM.. |
Good to know. That is high praise from a guy who is an upholstery/interior god. The work that comes out if your shop is fantastic/art!
