G50 Rebuild Questions
1) What size socket do I need for the big nut on the main shaft?
2) My output shaft seal surfaces have some corrosion--black discoloration which you can feel with a fingernail in places. Are they going to leak? Another way to put it is do the seal surfaces have to be pristine to not leak? Thanks, Casey |
If you can feel it, it's rough enough to prematurely wear out a new seal. Needs to be smooth as a baby behind!
Kind of what I figured! Thanks!
| All times are GMT -8. The time now is 08:42 PM. |
