Targa top question
I've noticed that around the rear clips (inserted into the mounting holes on the roll bar) for the top there are plastic bezels that I'm guessing are used to reduce noise. One of mine is missing. Where can I get these?
It's not important to be the best, just do your best.
Old 09-13-2002, 12:43 PM
Is this it? Duh, I guess that I should've checked this site first before posting a qhttp://www.pelicanparts.com/catalog/shopcart/911M/por_911M_sunrof_main.htmuestion.
Old 09-13-2002, 12:50 PM
Early_S_Man's Avatar
Porsche Crest
Cover for the Silentbloc pins ... 911.565.217.40
Pelican, or any dealer ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-13-2002, 01:02 PM
great, thanks guy.
Old 09-13-2002, 01:05 PM
steve911's Avatar
there was a thread on how to install these not too long ago; I'll see if I can find it.
Grease the pin lightly, slip the cover over it then heat it up with a hair dryer or a paint stripper 'gun'. Slides right on.
go here
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 09-13-2002, 01:18 PM
one of gods prototypes
bell's Avatar
double check to make sure it isn't stuck in the receiving hole, i had this happen when i first bought my 85'
Brought to you by Carl's Jr.
Old 09-13-2002, 01:49 PM
FranksPlace2's Avatar
Smile
Targa77,
Did you see that post by Peter Stey in August about the Targa Top installation instructions?
He sent a copy to me (2 megs pdf file). They are quite clear with a lot of pictures.
Makes me want to try it next year. (I just got my engine completely rebuilt!)
Frank
'77 911S Targa
Old 09-13-2002, 02:20 PM
I recently installed new covers myself using the hot water and lube method, but also used a 7/16 deep well socket slipped over the cover . The socket catches the little shoulder on the end and gives more push on the leading edge for easier installation.
Jerry
Old 09-13-2002, 07:20 PM
Good tips guys and thanks again to all that replied. If I need someone to bail me out, I'll let you know.
Old 09-13-2002, 07:28 PM
MBAtarga's Avatar
I posted the original question in the link above. The hot water treatment that Warren suggested works wonders!
Mark
'83 SC Targa - since 5/5/2001
Old 09-13-2002, 07:33 PM
