warm start issue 911 3.0 sc
hi
the car won't start when it's hot..the car is 911 from 1968 with engine 3.0 sc from 1980
new parts:
fuel filter
fuel pump
fuel accumulator
injectors
WUR is testet 1.5 bar (cold) 3.6 bar (Hot)
it's a clean engine without lambda and control box, when i check the fuel pressure(cold) it goes to 1.5 bar and within minutes then goes to 3.5-3.6 bar, but when i take the ignition off (fuel pump) the pressure drops to 0 bar right away.
what is keeping the pressure in the system? when the pump is off, i can understand that it's a combination of the pump and the accumulator, but what about the return fuel line, should there be some kind of valve to stop the return and hold pressure.
i am a bit confused about this.
BTW. engine starts fine when it's cold
Br
Michael
Old 07-10-2017, 01:20 AM
proporsche's Avatar
Hi ..yes there is a fuel pump check valve...like this one..that could be your culprit.
Ivan
Old 07-10-2017, 02:36 AM
Residual fuel pressure.........
Michael,
Test your residual fuel pressure. Your pump might not have the check valve used in later CIS cars or the check valve is leaking. Test and inspect your FP.
Tony
Old 07-10-2017, 03:29 AM
Banned
Ivan
In what way?
Old 07-10-2017, 05:07 AM
ROW '78 911 Targa
timmy2's Avatar
Residual pressure is on supply side. None on return side.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-10-2017, 09:50 AM
Fuel pump check valve..........
Originally Posted by ixxified View Post
In what way?
The FP check valve prevents the return flow of the fuel to the gas tank after the FP ceased running. Thus preventing the sudden loss of residual fuel pressure in the system. There are several known culprits to cause residual pressure loss and the FP check valve is one of them.
Tony
Old 07-10-2017, 09:55 AM
hi
yes yes...found the problem, there were no valve in the in the fuel pump on the pressure side, i will install one and check/test again.
Thanks to all for quick response and help to solve the problem, i will write back when i have tested it.
Br
Michael
Old 07-10-2017, 11:55 PM
