1:18 vinyl decals
Guys- any idea where I can get a set of Brumos vinyl decals like their old 917 to put on a 1:18 model 962 ?
Try PattosPlace: Slot Car and Model Car Decals <-- That's all the names under "P" (Prsche). Porsche is spelled without an O, I guess to avoid copyright infringement? Scroll down to "Prsche 917-10 Can Am - Brumos" and you'll find this: Looks like you can get it in either waterslide or adhesive (probably extremely thin vinyl). Typically waterslide (along with surface prep and clear coat) is the most long-lasting application. However, adhesive would surely be easier. The following are slot-car sized, and likely waterslide. Perhaps they can be scaled up, decals are typically vector based. 1/43 (click image): ![]() 1/32: There are slight differences in the stripes on each one. I don't know if some are more accurate, or if the actual livery changed slightly. eBay may have some more. If those don't work, you may need them custom made. . Last edited by FrenchToast; 06-10-2017 at 09:55 PM.. |
Thanks for the lead- I actually found them on GOOGLE but didn't scroll down far enough.
1:18 vinyl decals
Got them from Pattos place in Australia
