Transaxle rebuilding question
Hi!
On my last stage putting my 911T 2.0 1969 back together I run into a question regarding my transaxles.
In the overview picture one can see the extra spring washer (bottom middle (green arrow)
This ring was in the assembly as I took it apart many years ago.
In the second picture one can see the markings from where is was mounted in the assembly (red arrows).
It is a 901 dog leg transmission with transaxles from ’69.
All the exploded views I saw there was no (spring) washer…….
Anyone any idea?
(hope so ;-)
Regards,
Bart
Old 04-14-2014, 05:16 AM
pete3799's Avatar
Those look like the spring washers that go on the shaft first (cup side towards the CV) but I don't know what would have caused that wear pattern as that's the side of the washer that would be against the CV.
Pete
79 911SC RoW
Old 04-14-2014, 05:52 AM
Hi Pete,
Thanks for quick reply!
Do you got/know exploded view!?
So washer will spring load cv, must be difficult to add 'lock ring' any advice?
Cheers,
Bart
Old 04-14-2014, 12:12 PM
Senior Member
Jdub's Avatar
Yes. You may need to push down hard to get the circlip ("lock ring") in. Before you start, use a brass brush to remove all crud in the grooves and slot. Test slide the CV joint and be sure it moves fully onto the axle. Put the C cup on, then put the circlip on with flat edges towards the CV (look closely and note the way the circlip was stamped - one side/edge sharp, the other not).
'78 Targa in Minerva Blue
Old 04-14-2014, 12:21 PM
Hey guys,
As a Dutchie I maybe misinterpreted the answers....
Maybe this helps clarify.
[1] axle
[2a] spring washer (spherical/convex side down) (that will also explain wear patterns on spring washer side touching CV)
[2b] spring washer (spherical/convex side up)
[3] CV
[4] circlip
So the order to mount is:
1-2a-3-4
Does everyone agree on that?
Thanks again,
Bart
Old 04-14-2014, 11:15 PM
