3.2 pings even with 91 octane
I have a stock 3.2. No mods at all. Maybe 10k miles on full rebuild. Passes CA emissions. Runs well - but - it pings on hard accel at 5k rpm with oil temp at 200F with 91 octane. Is this common?
Old 04-13-2014, 09:03 PM
Rescuer of old cars
Arne2's Avatar
No, I don't think so. Mine has never pinged that I've heard, not ever.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 04-13-2014, 09:14 PM
Definitely not common! Check for aftermarket chip and possible lean condition due to vacuum leaks.
Old 04-14-2014, 12:39 AM
IROC's Avatar
Is this pinging from one tank of gas? I've gotten a bad tank of gas before that has resulted into some pinging that was not typical.
If it is typical, then, yeah, you have some sort of issue.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-14-2014, 04:22 AM
Check the operation of the Wide Open Throttle switch. That was my issue. Bad solder joint inside. Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 04-14-2014, 08:29 AM
Chain fence eating turbo
This is sound advise. The WOT switch adds fuel (ignores O2 readings) for extra power IIRC. You're too lean at WOT if it isn't activating.
Old 04-14-2014, 10:14 AM
Good ideas - thanks all.
Old 04-14-2014, 06:41 PM
