-   -   3 point rear belt conversion question (http://forums.pelicanparts.com/porsche-911-technical-forum/806451-3-point-rear-belt-conversion-question.html)
alfisti 04-15-2014 02:59 PM
Hi folks. I feel like a fool here, but somewhere, I have seen a photo with measurements, on where to put the holes (and what shape) in the rear parcel shelf, to install rear shoulder belts.
I finally have all the parts (including the two "trim rose" pieces) but want to "measure twice, cut once" as they say.... and best I can do right now is eyeball pictures of the outside of the shelf with mounted trim rings and belts.
Anyone know where I can find this, or have a 964 or 88/89 Carrera they can measure for me?
-Glenn
alfisti 04-16-2014 07:02 AM
Anyone? :-)
Jp-oh 04-16-2014 07:28 AM
I did this not too long ago and did so without measurements. I used a template made from cardboard (as some before me had suggested). Mount the belts on the rear deck and cut a large cardboard panel to mock up the parcel shelf and figure your hole position and size on that then use as a jig to cut holes on the parcel shelf.
trader220 04-16-2014 07:31 AM
I just did this in my 1987. The if your car is a 1984 or later it will already have the threaded mounting points under the reardeck. You can remove the deck and easily measure yourself.
I live outside Philly, if you're near by, I used an old deck I bought off of eBay to make a stencil to plot the holes I needed to cut in my reardeck, you can have it.
alfisti 04-16-2014 07:34 AM
Thanks. I'm in good shape with the hole for the screw - just have to hack up the parcel shelf.
That's a good idea on using a cardboard template.
Can I ask you folks - how close is the top edge of the hole to the "bend" in the parcel shelf? And, am I correct in saying that if the hole is properly cut, the trim will "pop in" and stay?
-Glenn
alfisti 04-16-2014 09:49 AM
trader220, are you going to Hershey?
I live in central NJ, may be doable to meet - but might even be easier to meet at Hershey.
-Glenn
Jp-oh 04-16-2014 10:12 AM
-Glenn
Here is a pic of mine. The rosettes sholud be able to stay put themselves in a reasonably cut hole. I think I may have gone with super classy high end black duct tape.
http://i712.photobucket.com/albums/w...pse3e4bea0.png
trader220 04-16-2014 10:44 AM
I touch of epoxy on the underside of the rosette. The factory had bendable fasteners but they had the luxury of doing before the trim was on the deck card.
I wont be at Hershey, sorry.
