michael lang's Avatar
What is the best way to get this out?
I'm trying to remove the head temp sensor without damaging anything but don't have a correct tool to remove the sensor. Can anyone make a suggestion on what I can do? One of my techs had told me to just snip the harness and get a whole new sensor since I will be getting new reference and speed sensors. Any thoughts on what is the best thing to do?
Mike
'89 CARRERA
#402
Old 04-25-2014, 06:02 AM
How about a brake line wrench?
Chris
'75 911s 3.2 - Ice Green Metallic
‘87 951, '05 987 S
'21 Jeep Gladiator
‘18 Tesla ModelX 100D, ‘20 Model 3
Old 04-25-2014, 06:05 AM
Diss Member
Quicksilver's Avatar
I went and bought a cheap deep socket and used a 1/4" grinding wheel to cut a slot all the way through one side of it.
Can't recall how many MM it was. Maybe 13mm?
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 04-25-2014, 06:07 AM
Just Kidding. Cut it and use 1/4 on a swivel or a wrench it's an easy one
the grommet is a little finiky when putting it back" Soap it up.
Old 04-25-2014, 06:08 AM
I cut a slot in an offset box wrench to get it if you don't want to cut the wire. Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 04-25-2014, 06:20 AM
Bird911's Avatar
This is what you need:
So here is my story:
I tried for an hour to figured out a way to take this sensor out without success. Then I read in Pelican's parts section that it is a good idea to change this sensor if it is too old. So I just gave up and I cut the wire to remove it with a regular wrench.
The next day I found the flare nut wrench in a lost corner of my tool cabinet... oh well, another $95.50 to spend for the sensor... Lesson learned.
The best thing to do if you don't have access to this tool, is to use a cheap box or closed wrench and cut a slot in it with a grinder.
Hugo
Old 04-25-2014, 06:48 AM
If you don't know how old the sensor is, replacing it is the smart thing to do.
I just bought a cheap deep socket and cut a groove in it with a Dremel grinder to put the new one back in.
Old 04-25-2014, 07:27 AM
can you post the socket size after you do it?
Rick
88 Cab
Old 04-25-2014, 08:30 AM
Stutzdriver's Avatar
I believe the original 1 wire (which we all should replace) is 13mm, the replacement 2-wire is 14mm? someone should be able to confirm this...
I'm about to replace mine and i plan on snipping the wire on the old one to remove it and then slot an old 14mm socket to install the new one. I'm not at home so I can't measure the new one that is on the workbench.
Jay Traner
1984 911 targa
1923 STuTZ 690 Touring
2014 VW CC 2.0T
2021 Subaru Forester (Mrs)
Old 04-25-2014, 08:47 AM
Spiderman
Jesse16's Avatar
Sensor Replacement
I just did this recently.
1. Get a new sensor in hand.
2. Cut the wire on the old and use a regular socket to remove.
3. Get a donor socket, probably deep well that fits the new sensor and slot it to pass the wire (just like an O2 Sensor Socket you can buy) I used a 9/16" one in my box that never got any use. Does not have to fit "perfect" you aren't going to torque this thing in much.
4. Install and enjoy.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 04-25-2014, 09:16 AM
I have the flare wrench that normally would work perfect, the problem is there is not enough clearance around between the sensor and the head. The cooling fins are getting in the way of the wrench. I'm just going to cut the damn thing and replace the sensor. I will have to modify a wrench or socket when I install the new one. Thanks for the help guys. I know I'll have a ton of this kind of stuff as I continue to disassemble and go back together.
Mike
'89 CARRERA
#402
Old 04-25-2014, 10:24 AM
Aircooled Breakfast
There are two versions of the head-temp senders. The early version was 13mm and the later, two-wire version, is 14mm. A deep socket modified as shown above is the ticket.
Old 04-25-2014, 10:57 AM
Go-Kart Mozart
JAR0023's Avatar
If you don't want to make a socket or just want an excuse to buy another single use tool, search for Injection Line Flare Nut Socket. 14mm is common on some Euro diesels. Most aren't cheap, though. From $20 Ebay to $100 plus Snap-On. -J
Laser Injection Line Flare Nut Wrench 14mm 3 8" Drive Fuel Injection Tools W | eBay
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 04-25-2014, 01:48 PM
